AGM battery for Gen 4/Gen 5 Prius/Prius Prime and observations on the 12-V charging system
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Sep 20, 2024.
  1. Gokhan
    Gokhan Senior Member
    5,984
    2,372
    Paramount CA
    The flooded-cell Toyota TrueStart H4 sounds good.
    Do you know why your OEM GS Yuasa failed so early?
    You can post a table instead as well.
    Google Sheets is almost as good as Excel, and it’s free and cloud-based.
  2. Gokhan
    5,984
    2,372
    Paramount CA
    Yeah, the battery-management system does not charge the 12-V battery at gun point, except once every 20 driving hours. LOL
  3. RandyPete
    RandyPete Active Member
    401
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    -No I do not know definitively why the original Yuasa battery failed.
    -I did observe resting voltages at 12.3 v many times.
    -I had it 'tested' at the toy dealership several times. Each time they noted that it was still a good battery.
    -The local dealership had the car for 3 months to replace the traction battery because of ac/heat pump gas leaks within the traction battery assembly. During its extended stay at that dealership, after about 1-1/2 months of waiting, I did visit the dealership one time to check on the car. It was parked in the back 40 and the battery 12v battery did not even have enough charge left in it to allow the fob to open the front drivers side door. They used the mechanical key from the fob to open it, trying to exclude that info from me. But I cought it. The car would not go into the ready mode at that time either.
    I believe that a flood lead acid battery stored at 12.3 v or less is subject to accelerated sulfation. Something I learned from installing really big battery banks at a facility I worked at over the years and read about odyssey battery maintenance on their site. The battery university also has info on flood lead acid battery sulfation, as do many other battery maintenance sources.
    Roy Peterson and Gokhan like this.
  4. Roy Peterson
    Roy Peterson Member
    95
    125
    Richland WA
    2024 Prius Prime
    I'll share some recent data I recorded on my 2024 Prime with the AGM battery.
    2 November - charged the traction battery with my level 2 charger. Charge complete late afternoon
    3 November
    - morning I checked the battery charge with the BM2 and it was 12.87 volts. Any surface charge should have been depleted by then. Drove 47 minute trip in HV mode. Initial 14.3 volts that transitioned to 12.8 volts in @ 3 minutes time. The remainder of the trip the voltage stayed at 12.8 volts and for most of the trip there was a slight discharge until the end portion where it was basically neither a charge or discharge. Battery temp was 60 F.
    Drove a second 47 minute trip in HV on same route. Basically the charge voltage scenario same as first trip.
    4 November
    - voltage in the morning was 12.68 volts. Did not drive the car that day.
    5 November - voltage in the morning was 12.64 volts. Its getting colder here which will have some affect on battery capacity. I noted that the traction battery mileage estimate was decreased 2 miles from where it was in warmer weather
    Charging voltage initial was 14.3 volts (@6 amps current) and stayed at that level for 21 minutes then gradually dropped off to 13.1 volts. Trip length 32 minutes in HV mode.
    Return trip EV mode initial charge voltage 14.3 for 3 minutes then transitioned slowly to 13.1 volts for remainder of trip. Total trip time was 15 minutes. Took short way home :)
    Checked battery voltage several hours after arrival. Reading 12.88 volts. I would expect that surface charge was depleted since I had opened and closed the rear hatch on arrival which has a fairly significant current draw.
    So for my situation, the AGM battery is working to my satisfaction.
    One side item I noted. I was recording aux battery current and DC-DC converter current. I noted that often during the transition from the 14.3 initial voltage, the DC-DC output current drops to zero for a few seconds and the battery current increases to a negative -20+ amps. basically picking up the DC requirements for a few seconds and then the DC-DC converter comes back to carry the current load. I believe this is one parameter the HV ECU measures to determine battery capacity, SOC and SOH.
    Cheers
    RandyPete and Gokhan like this.
  5. kiwiscoot
    kiwiscoot Member
    60
    30
    Christchurch New Zealand
    2019 Prius Prime
    Well after I read this thread I went and checked my 2019 Prime and the 12V battery was 12.2V after about 2 hours of the car resting after my EV City mode drive from work - 6kms /3.75 miles. Put my intelligent charger on and it went to the de-sulphating program immediately. Fully charged this morning but I will keep an eye on it. Had no issues yet but I have only owned the car for two months - has 44000kms /27500miles on odo.
    Thanks for all who shared their expertise and experience.
    buztabuzt and Gokhan like this.
  6. Gokhan
    5,984
    2,372
    Paramount CA
    If it was that low, I would replace it with the Uplus AGM battery at this point. Batteries with sulfation will have artificially high voltages when charged but without actually a good Ah capacity during discharge.
  7. vvillovv
    vvillovv Senior Member
    4,320
    1,508
    NY
    Whatever anyone else thinks about the Gen 4 Prime 12volt system, my take is that it's always better to monitor the system the way the car shows it in techstream or an app ( DrPrius, HybridAsstant, Torque or CarScanner ) are the ones I know show how the car handles the 12 volt system.
    My understanding so far from reading posts here and monitoring my Primes 12 volt system is that 12.2 resting voltage reading is normal for Gen 4 Prime. As soon as the Prime is put into Ready mode the voltage I've seen goes straight to 14 or 14.x volts. Than depending which mode and which engine motor combination is selected the behavior can be very different during the drive session.
    My 2017 Primes 2nd OEM 12 volt battery rests at 12.2 volts normally, at least when I've checked it with both a voltmeter and any of the ( apps I mentioned above ).
  8. Gokhan
    5,984
    2,372
    Paramount CA
    No, a 12.20-V resting voltage (after at least 16 hours of rest) is only a 62% SOC for a flooded-cell battery, which is not normal or healthy. It means that the battery Ah capacity has probably degraded because of sulfation. In fact, if there is sulfation, the SOC would be a lot less than 62% for 12.20 V in a flooded-cell battery. If I were you, I would hook up a battery maintainer periodically to extend whatever lifespan is left in the battery.
    buztabuzt likes this.
  9. RandyPete
    401
    167
    2024 Prius Prime
    XSE
    Did you charge (de-sulfating) the 12v battery in place or disconnect it from the Prius ?
  10. RandyPete
    401
    167
    2024 Prius Prime
    XSE
    Is it the stock battery a flooded lead acid battery or an AGM battery in your car ?
  11. Mr.Vanvandenburg
    1,345
    563
    2020 Prius Prime
    I’ve been watching the recorded graphs of the voltage many months now. I never see 12.2 volts resting. On pushing start button it does not immediately go over 14 volts. There is a big sharp dip to about 12.4 possibly lower, then it goes up. From usually 12.5x to 12.7x resting.
  12. RandyPete
    401
    167
    2024 Prius Prime
    XSE
    Good info about AGM deep cycle marine lead acid batteries.
    Concord is the battery manufacturer, Made in the USA, West Covina, CA
    Lifeline is the battery brand.
    I used two of the GPL-31XT 12v AGM batteries in parallel in a 4WD popup camper for a few years. Charged them with a RedArc DC-DC charger from the vehicle battery/alternator and from Solar Panels. The setup worked exactly as specified by Lifeline and RedArc. Sold the camper with the Electrical System in place after using it for about 4 years.
    Here's some info about that AGM Battery and Technical Battery info from Lifeline for their AGM batteries.
    Lifeline GPL-31XT battery specs:
    GPL-31XT AGM Battery - Lifeline Batteries
    Technical Manual for Lifeline Batteries:
    https://lifelinebatteries.com/wp-content/uploads/2015/12/6-0101F-Lifeline-Technical-Manual-Final-5-06-19.pdf
    For some reason I cannot cut and paste text from this PDF file. SO a screen shot will half to work:
    AGM Battery Charging:
    Charging continued:
    Conditioning:
    Deep Discharge recovery:
    The logic of 'walking AGM battery life down' by not charging it to 100% SOC at nearly every recharge point is detailed in the screen shots above.
    And this is what I believe will happen to AGM 12v batteries in Gen5 Prius Primes because the Toy battery charging Protocol in the gen 5 is not matched to the AGM battery charging needs.
    If you charge it about once weekly with an ac automatic (3-stage) AGM battery charger I believe the battery will last longer than if you neglect to fully charge it on a routine basis.
  13. Gokhan
    5,984
    2,372
    Paramount CA
    It is the same problem with a flooded-cell battery. An AGM battery will still cycle more times under the same charging conditions.
    The Gen 4/Gen 5 Prius/Prime battery-management system is agnostic to the type of the lead–acid battery (such as standard flooded-cell, calcium flooded-cell, AGM, EFB, gel, etc.), as it measures both the current and voltage to calculate the SOC, SOH, and SOF.
    You said that your SOC has been running pretty low (a 12.3-V rest voltage). So, your flooded-cell battery has been degrading rapidly as a result.
  14. Gokhan
    5,984
    2,372
    Paramount CA
    Resting as in at least for 16 hours? That would be 87.5–105% SOC. You said that your car hardly every charged the battery, and others have been getting much lower resting voltages.
    #114 Gokhan, Nov 8, 2024
  15. vvillovv
    4,320
    1,508
    NY
  16. RandyPete
    401
    167
    2024 Prius Prime
    XSE
    Yes my flood factory stock Lead acid battery performed poorly in my 2024 Prius Prime. Many have had this experience. 12.3v resting voltage is a battery killer in the short run (6 months). I figured the battery was under warranty and chose not to charge it with an ac charger maintainer because the vehicle should do that and if it does not, the warranty should stand. (It is a hassle and a pain to get a stock 12v battery replaced under warranty in a 2024 Prius Prime).
    In my case I believe that the dealer installed vehicle theft deterrent system contributed to the stock battery failure. It's a KAAR SECURITY SYSTEM by SWDS. It makes the lights flash and horn honk upon locking the doors and if I try and open any door when the system is on. There is a blue light that continuously flashes brightly inside the cab when the system is on. I cannot get any info on its control or set features. But it does draw power when the doors are locked. This option was not a choice on my part. The dealership I chose to buy from included this system on every Prius they sold. There was no dealership markup on the MSRP price, but the dealer installed option was mandated and had a cost. That option cost was less costly than the $5000 dealer markup on the same car at my local toy dealership at the time.
    #116 RandyPete, Nov 9, 2024
  17. Gokhan
    5,984
    2,372
    Paramount CA
    That should not be hard to find out what it is doing using the battery monitor. Nevertheless, I doubt that was the problem. Even if it was causing a higher parasitic drain, the battery would charge the next day if the battery-management system wanted to charge it. However, it doesn’t—as I’ve been explaining in this thread.
  18. Mr.Vanvandenburg
    1,345
    563
    2020 Prius Prime
    Mine had a Spireon lojack. I found the fuse for it under the dash, inline fuse on a red wire. Someday I will remove the whole thing. Yours sounds more complicated, but there should be a way to disconnect.
    I’ve settled in to manually charging when soc gets into the low seventies. Not much else can do.
    RandyPete likes this.
  19. Gokhan
    5,984
    2,372
    Paramount CA
    Yes, even if you eliminated all the third-party accessories, the native parasitic drain of the car is several-% SOC everyday. Since the battery-maintenance system does not charge the 12-V battery no matter how long you drive the car, you are still at a risk of the SOC staying too low.
  20. kiwiscoot
    kiwiscoot Member
    60
    30
    2019 Prius Prime
    I left it in place.
