Air bag helper spring install
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Yippeekyaa, Sep 21, 2017.
  1. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    IMG_6330.JPG IMG_6331.JPG IMG_6333.JPG IMG_6334.JPG IMG_6335.JPG IMG_6336.JPG IMG_6337.JPG IMG_6338.JPG Installed the firestone helper air bag kit in the rear coil springs. This was the second time installing the kit in a Prius. First was a 2011. Total time 45 minutes. Found a shortcut that simplifies inserting the bag in the springs. By removing the one bolt at the end of the lower control arm the entire spring can be easily removed. This bolt is not one of the camber bolts so it doesn't change the suspension geometry by removing/installing the bolt.
    Important note!!!
    Mark the spring location before removal. I used some nail polish. Put it back exactly like it came out.
    25psi when I'm towing my tiny camper keeps the car level and no more high beam flashes from oncoming traffic. 10 psi when not towing seems to be the most comfortable. Ymmv. Feel free to ask questions.
    ydpplqbd, MTN, Burna J and 2 others like this.
    52,816
    great job, thank you!(y)
  3. plug-it-in
    plug-it-in Active Member
    179
    113
    Kitchener, ON, Canada
    I don't think I am interested, but congratulation! Neat job, with good information re
    maintaining the spring location.
  4. kikik
    kikik Junior Member
    83
    44
    Maine
    Hi there, is there a reason you left the top plate off?
