Air Bag lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sabercat, Nov 21, 2019.
  1. ChapmanF
    18,249
    Perhaps, in a car where you have zero reason to suspect any of the other reasons the SKS might not be working.
    I'm not sure that sounds like this car though.
    We've already had Aftermarket Я Us in there with their wires and tape trying to make a remote starter work, and giving up, and taking most of it back out (to the very highest of workmanship standards, one can only assume). And it's already reported that other stuff is acting weirdly.
    The antennas for detecting the fob inside the car are located in a few places, as shown in the wiring diagram. If I remember right, Techstream can show you some info about the different regions covered by the antennas and where the fob is being detected. That might lead to some clues about what bits need to be put back together.
    It's even possible for SKS to be turned off, in which case only holding the fob to the button will work, as designed. There isn't a handy switch for that in Gen 3 as there is in Gen 2, but there is a chicken dance for it.
    sabercat and Elektroingenieur like this.
  2. Elektroingenieur
    2,515
    3,284
    Three Touring
    This is an important point. I’d start with the dome light and air bag problems, myself.
    Yes, and then wait 90 seconds. See this posting and the Repair Manual.
    Unless you’re working on the high-voltage parts of the hybrid system, that’s probably not necessary. As long as the car is not in READY, the system main relays will be open, isolating the HV battery.
    sabercat likes this.
  3. sabercat
    sabercat Junior Member
    48
    Mid-Mich
    2001 Prius
    Thanks, so if the sks got turned off, How could test for that, and reset.
  4. sabercat
    48
    Mid-Mich
    2001 Prius
    Well great news, I started checking the fuses in the engine compartment box, and the 7.5 fuse was blown. Thanks to all of you
    dig4dirt and bisco like this.
  5. bisco
    51,996
    if the buttons on the fob won't lock/unlockwonderful, what circuit is that fuse for?
  6. sabercat
    48
    Mid-Mich
    2001 Prius
    its the 7.5 ECU-B smart key system, multiplex communication system, personal lights, gauges and meters. its located in the fuse box under the hood. page 465 #30
  7. bisco
    51,996
    ah, well done!(y)
  8. sabercat
    48
    Mid-Mich
    2001 Prius
    there is also another 7.5 fuse, labeled ECU-B2, Smart key system, in the same fuse box
  9. bisco
    51,996
    interesting
  10. sabercat
    48
    Mid-Mich
    2001 Prius
    one may be for just the key itself, verses the one on mine that was blown affected dash lights/seatbelt lights etc.
  11. ChapmanF
    18,249
    The labels on the Prius fuse box are about as good as the ones on grandpa's fuse box, where one of them will say "fridge" and nothing about the other 15 things on that circuit. Really the wiring diagram (more info) ends up being where to go if you really need to know what's downstream of a particular fuse.
