Air Bag OFF light no longer lit
Discussion in 'Gen 3 Prius Main Forum' started by J Humes, Dec 12, 2019.
  1. J Humes
    J Humes Junior Member
    26
    16
    PDX
    Four Touring
    2012 Prius Four -
    I noticed yesterday that the annoying, always-on when the passenger seat is unoccupied "AIR BAG OFF" light no longer lights with the engine running.
    I sat in the passenger seat with the car running and the "AIR BAG ON" lamp does come on.
    Should I be concerned?
  2. ChapmanF
    19,050
    If I remember right, neither light is meant to be on when the seat is completely unoccupied.
    When the seat is occupied with a weight pattern that the car classifies as an adult human, AIR BAG ON should light.
    When the seat is occupied with a weight pattern that is classified as a child, or stuff, AIR BAG OFF should light.
    When there's really nothing there, no light.
    Maybe the OCS was a bit miscalibrated or something was stuck on or under the seat making it think some stuff was there, and now not?
  3. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    I put a cooler in the passenger seat sometimes. If it's heavy enough, it will activate the air bag,
    and the stupid seat belt ding goes off! And it won't shut off until you buckle the seatbelt.
    I hate al those stupid things.
    vlxerdon likes this.
  4. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Agreed -- that was the first thing I changed with the Caresta app.
    ASRDogman likes this.
  5. ASRDogman
    8,069
    4,092
    I guess techstream can turn it off too. The first thing I did was turn off the constant back up beeping!!!
  6. J Humes
    26
    16
    PDX
    Four Touring
    Thank you to all that replied.
    I did buy the car used so it could have had something lodged under the passenger seat that moved to cause the static display change to "all lamps off". That morning I had to go through a semi-rough patch of road construction. With the Prius Plus package on board, it was a teeth-rattling ride.
    Thanks again.(y)
  7. Mendel Leisk
    42,369
    Maybe the light burn out.
