Air Bleeding with techstream
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Naimc, Oct 6, 2023.
  1. Naimc
    Naimc Junior Member
    Montreal
    Upgrade
    This is has been on my do list for while, I did not know what do expect here is my mini-summary.
    I used an ebay mini VCI and a 2021 version of techstream ( one with a loader that by-passes the requirement for a license)
    Prius AirBleed over view, total time 1h30
    Start of techstream / select the ABS/VSC/TRAC , the under utility AirBleed..
    the entire process has multiple reminder for re-adding fluid to the Max line
    The High Pressure tube ... step is all automated.
    The braking system makes a bunch of noices.
    An other automated step.
    Finally the person in the driver's seat start interacting with the brake pedal, this goes on for a few cycles.
    Next step start with reminder to check fluid ? why nothing has been opened yet.
    Now the real work starts, pedal operator pumps the pedal a few time, we did 3-4
    - Line one, Each wheel goes throught at least 1 cycle of pump brakes 3 times, hold pedal depressed Open bleeder let open till liquid stops flowing, and it clear of bubbles. repeat as many cycles as required.
    This goes on for RR, RL, FR, FL. ( we did 3 cycles on each caliper)
    Then with foot still on pedal I open the bleeder screws.
    10 mm wrench on the rear
    8 mm wrench on the front
    the cycle gets repeated for each wheel :
    After line 1 is done you start all over for the Line 2 !, but between those steps the car does a Actuator bleeding :
    - Line 2 bleeding start,
    Identical to line 1 all over again !, here is the RL slide,
    When the Line 2 section is finished running around opening bleeder screws is finished the rest is all internal :
    Noisy stuff and alarms start going off in the car.
    Pump cycling and valve adjustment, 6 cycles pump is noisy all sorts of alarm and light go off on the dash.
    It spends allot of time, doing 6 cycles of this step.
    Asking for Fluid check
    Valve learning part
    Lights on dash light up again :
    Done !
    Total fluid used about 500 ml, and you to be two , or use a rod to keep the pedal depressed when it calls for the bleeder to be opened.
  2. ChapmanF
    15,477
    Thanks for the detailed post!
