Air compressor to remove wheel nuts
Discussion in 'Gen 3 Prius Main Forum' started by pyrotalk, Apr 25, 2013.
  1. Spaz
    Spaz Junior Member
    82
    25
    New Jersey
    3 gal compressors are great. Small, portable and good to run a number of tools. I originally bought mine to run nail guns and stuff but it works great for small air tools and filling tires.
  2. Much More Better
    Much More Better Active Member
    655
    163
    What are people's opinions on the issue of water inside the lines of the compressor? Do all of you have filters in your lines?
    I just use an el cheapo $20 noisy 12v dc compressor. Yes, it's slow but once I get it started, I do other things around the garage. I don't have any air-driven tools so for me to get a compressor setup just to inflate tires is overkill.
  3. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    Your referring to dedicated lines that would need that. If that's the case, inline filters work just fine. If no dedicated lines, then just drain moisture from the tank.
