Air conditioner blower motor fix.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 4priusowner, Jun 10, 2018.
  1. 4priusowner
    4priusowner Junior Member
    69
    I have a 2005 Prius that for the last uear would only run the AC on low speed no matter what. Then it stopped working altogether. I replaced the blower fan and still same thing. Yesterday took it to AC repair place and they said it was electrical problem and the compressor was working fine. Took it to an electro mechanic and he said I have to leave so they can take everything apart and check. I then checked the old fan, which I still had directly to the battery and it ran fine So after talking with our friend Eric on this forum, I decided to disconnect the fan from the regular place and run a jumper from the cigarete lighter to the new fan directly. This was after checking that the new fan ran ok also.
    Wah la, now have full speed blower all the time when car is on. I can controll the temperature, but not speed of fan. I live in Puerto Rico so this is an ok temporary fix as it's always hot here and we have to use AC most of the time. Especially now in summer.
    We are guessing that there must be a bad sensor that doesn't recognize something, so won't turn on the blower even though there is 14.4 volts at the plug when you switch on the AC. Puzzeling, any thoughts on this or has anyone had this problem, any help would be appreciated as I really don't need the fan on all the time and don't want to burn it out. Thanks in advance for any insight any of you might have.
    52,773
    did you replace the pc board with the fan? what about the switch?
    ITBland likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Here's a basic drawing and component location diagram. B2, B3, B4. The SI input on the blower motor controller comes from the AC controller. That's located near where A19 is pointing. Most cars default to full speed (only) on the fan when the controller/resistor fails. Perhaps the Prius defaults to slow speed?
    #3 TMR-JWAP, Jun 10, 2018
    ITBland, SFO and bisco like this.
  4. TMR-JWAP
    6,404
    6,094
    Columbia, SC
  5. 4priusowner
    69
    No, where is the pc board and what switch re you talking about? The dash display switch both manual and automatic seem to be working as I can now as always turn thetemperaturw up in auto mode and watxh the fan speed on tje display go don or vice versa. But the fan never turned on or before wa only in low. Now because it is direct it is alway on high but I still can control temperature.
  6. bisco
    52,773
    i thought there was a pc board attached to the fan, maybe gen 3? not sure.
    so what isn't it doing now? can't change fan speed in manual?
  7. JC91006
    16,933
    8,643
    There is a controller the fan plugs into. Search for a fan controller
  8. 4priusowner
    69
    Rhank you for the diagrams and info about the blower motor controller. I'm assuming what you are saying is that replacing this which includes the resistor may solve the problem. Only thing I don't understand is that, could it have defaulted to low at first and thwn finaly to off as it wouldn't come on at all as of late even though therw is 14.4 votls at the plug when ac is turned on abd nothing when off but stull wont start fan. I will order controller board and see if that fix it. Thanks alot, but at least for now I have cool strong blowing air in this heat of about 90 to 95 degrees during day.
  9. ChapmanF
    18,954
    It's an electronic speed controller, not attached to the fan, but attached to the duct nearby, so that it sticks into the duct and the airflow keeps it cool.
    In the olden days, fan speed would be controlled by a "resistor" (really a little board with two or three resistors, and the fan switch would insert more of them into the circuit for the slower speeds, or shunt around all of them for high speed). The resistors would get hot, so they also used to be mounted to a hole in the fan duct so they were on the inside and the airflow kept them cool.
    Because of the similar size and mounting location and (roughly) similar purpose, a lot of people still call the Prius fan speed controller a "resistor".
    -Chap
    4priusowner, ITBland and bisco like this.
  10. bisco
    52,773
    thank you!(y)
  11. 4priusowner
    69
    When plugged into correct plug fan won't turn on at all. Display can show all speeds and you can change them manually or auto by setting temperature but, at this time when plugged the fan doesn't move at all even though there is 14.4 volts at plug. I will order the fan conteoller fornthwbcar and try that. It only costs 25 on ebay.
  12. 4priusowner
    69
    Found it and will order on ebay. Will keepntou posted. Hopefully that has thebresistornin it.
    Raytheeagle likes this.
  13. bisco
    52,773
    thanks, all the best!(y)
  14. 4priusowner
    69
    I will recheck down there to find it and hopefully it is the one on ebay which I will order.
  15. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    The Toyota part number is: 87165-47020 (~$222 list, ~$160 from dealers online)(makes it easier to find on Amazon/eBay),
    AutoZone is Part Number: JA1680 (~$150)
    I just got one from my local Pick-N-Pull for cheap, still working > 1 year :)
    You want to be careful replacing it, it could have overheated and burned out (most likely), or the fan could have shorted and killed it (in which case replacing it may just burn out the new one.:mad:)
    Edit: Ha! I just checked the wiring diagram diagnostic for the blower motor (Looking for an ohm value to check the fan for a short) and the official diagnostic is to connect the fan directly to 12v power--if it runs at full speed, it is good, if not, replace. (I was looking for a complicated answer and got a simple Yes/No test. LOL)
    #15 ITBland, Jun 16, 2018
    JC91006 likes this.
  16. HughJazscheens
    HughJazscheens Junior Member
    There are (at least) two ways to slow a DC motor. The resistor method is described above. But since this system uses a dedicated electronic controller module, it's also possible to "chop" the 12 volt supply. In other words, the full current is rapidly turned on and off many times each second. The longer the "off" sequence is, the slower the fan motor will run. This causes less heat and uses less power than simply dumping the excess through a resistor by heating it up. This also typically generates greater strength in the motor, since the brief pulses it sees are still a full 12 volts, rather than a lower voltage and strength that would come from resistors. If you want to learn more, look up PWM or pulse-width modulation. PWM is used for a wide variety of control and signaling uses and is similar to how a lamp dimmer in your home usually works.
    The dashboard display shows what the computer is telling the module to do. It has nothing to do with what voltage the module is actually sending to the fan motor. Supplying feedback to the display would make things more complicated and expensive than is necessary.
    Therefore, assuming you can reach the wiring, try checking it with a voltmeter on a similar vehicle. I expect you'll find that the voltmeter gives different readings on each vehicle, showing that your controller module needs to be replaced. Since this is likely a ridiculously expensive fix, just go with the full-speed setup you have. Like you said, it's hot there. Also, it's quite possible that the reason the controller module failed is that it got too hot. Be glad it shorted out in the "on" state instead of the "off" state or you wouldn't get any air until you replaced the module. (This is also why you're supposed the check your bathroom's GFI every month. If it fails "on" it won't protect you from getting a shock.)
