Air conditioner blows warm when stopped
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drive2much, Jun 26, 2011.
  1. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    The fans don't reverse themselves. They are either right as they came from the factory or someone did work on the front of the car and got them mixed up.
    Are you having all the same symptoms as Drive2much?
    o AC cools well on first trip of the day.
    o As car warms up, AC is less effective.
    o When car is standing at a light or whatever, AC is at its worst.
    If your answer is yes to all of the above, I can't help you. The reversed fan idea seemed to be a possibility worth exploring.
    However, my advice about finding a reputable Auto AC shop still stands.
  2. psusi
    psusi Junior Member
    68
    24
    Orlando, FL
    Those symptoms could make sense with a stuck expansion valve. As the day wears on and temperature goes up, overall coolant pressure rises. In the morning it is low enough to work ok, but once the heat settles in, the pressure no longer drops enough across the valve to do much cooling. $950 sounds outrageous to replace it though.
  3. prius21
    prius21 New Member
    Oh
    2001 Prius
    Did you try to lower the cooling tem inside the car ?
    Because the might be ice in somewhere in your ac system wihch can affect your ac and that maype increasing as you slow down or stopping when the gas engin turn off and there will be no heat to milt the ice !!
    I hope that might help :D
  4. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    From manual:
    Condition:
    Periodically cools and then fails to cool.
    Symptoms Probable Cause Diagnosis Corrective Actions
    During operation, pressure on
    low-pressure side cycles between
    normal and vacuum
    Moisture in refrigerating system
    freezes at expansion valve orifice,
    causing a temporary stop of
    cycle. However, when it melts,
    normal state is restored.
    - Cooler dryer in oversaturated
    state
    Moral of story:
    Go to AC shop that can handle hybrids (non hybrid oil will damage your system)
    Evacuate, system, replace receiver drier, pump down and refill with dry freon.
    Moisture in refrigeration system
    and blocks circulation of
    refrigerant
    1. Replace receiver dryer
    2. Remove moisture in system by
    repeatedly evacuating air
    3. Supply proper amount of new
    refrigerant
  5. richard schumacher
    7,680
    1,059
    United States
    Coolant and oil must be replaced when the compressor is replaced. The wrong oil would damage or destroy the compressor.
  6. vertex
    672
    144
    new york
    2018 Prius Prime
    If the wrong oil was used, the AC would not work at all once the compressor fails. The oil causes the motor windings to short out.
  7. blown240
    blown240 Junior Member
    53
    SoCal
    One thing you may want to check is if the AC condenser has a lot of dirt in the fins. I doubt thats your problem, but its an easy enough thing to check.
  8. kammssss
    kammssss Member
    287
    86
    SoCal
    Here is a theory: Inverter Coolant Pump
    Today I got the triangle of death on the dash, which is the Hybrid warning sign. I just left the dealer right now with it being replaced via recall. This is what happens when the inverter pump is dead: AC will blow warm even when you put it on 65F. I don't know the exact relationship with the inverter pump and AC. They must work together somehow because the AC is now FREAKING COLD. I live in Los Angeles and it was 102F on the drive back home. AC was set on 78 and on the second setting. I know the stealership didn't give a complimentary AC charge. Also, I noticed that the AC was blowing on the weak side a few weeks ago. Maybe the inverter pump was not running at optimum level and consequently lowering the AC temperature. My car is an 05 with 186k. I hope that gives you some clue.
    Good luck.
  9. drive2much
    drive2much Junior Member
    42
    Denver
    I can definitely call around and see what other places would charge to replace the expansion valve.
  10. drive2much
    42
    Denver
    I can always give it a try. Thanks!
  11. drive2much
    42
    Denver
    Thanks for the info from the manual. I do not know what a receiver dryer is, but I will definitely look into it. Thanks!
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Just a SWAG, but I suspect that the car removes necessary loads from the inverter when that system is in distress. AC being one of the bigger non-essential loads.
  13. drive2much
    42
    Denver
    I have seen posts about the inverter coolant pump. Don't know much about it, but I'll look into that too. Thanks for the info!
  14. drive2much
    42
    Denver
    Just wanted to post a follow up. I made a phone call to Toyota USA, and they had a master Prius tech check my A/C. He said the compressor was bad. He also had reasonable explanations as to why it was the compressor versus the condenser or expansion valve. I had a new compressor installed today, and so far the A/C seems to be working. Thanks to everybody who posted suggestions and information!
  15. Tyrod
    Tyrod New Member
    Sunny Central Florida
    So now you know that the one of the first 4 that diagnosed the compressor is the knowlegeable one. What was the final bill?
  16. drive2much
    42
    Denver
    The total was $1417.
  17. lech auto air conditionin
    830
    606
    261
    san francisco
    Was the compressor the only thing they replaced?. Did the dealer state the the compressor burnt out? If so later you may have problems with a short compressor life because of metal flakes partly blocking the condenser. It may work for now but fail later. I'v seen many Toyota dealers just replace the compressor and later the customer is buying a 3rd one. There is a lot of little new diagnostic procedures bugs to be worked out on the new inverter ran compressors it,s old news to commercial and residential A/C and refrigeration units I work on but the automotive guys are just learning, trying to apply old school to the pruis. Often its more then one problem by the time the customer brings the car in for repair. Many times its more then one test and more then one recharge take apart and recharge and test a few other components. It's long and costly, the service writer, service manger, owner of the shop , and especially the customer dose not want to hear this. With the older and new system is now always so.
    If automotive shop were in charge of keeping our country food supply freezers and refrigeration working we would be a starving country. Would you put up with that, then why do we when it comes to our cars.
  18. drive2much
    42
    Denver
    The compressor did not burn out. The problem was that I had been in a front end collision. The master tech explained that the Prius compressor runs under very tight tolerances, and that the jarring from the accident is what caused the problem. He said that he has seen this happen before, and if you look around on PriusChat, you'll see other Prius owners that had front end collisions complaining of their A/C not working. It has been somewhere around a year since my compressor was replaced, and everything seems to be working well.
  19. lech auto air conditionin
    830
    606
    261
    san francisco
    So if I understand,you had been in a front end collision a year ago and a body shop worked on your car. Your A/C worked fine for about a year then your compressor went out?. Then the toyota master tech said this was caused by the jarring from the hit? if i'm understanding you correctly.
    Did the toyota master tech state on the repair order that the compressor took a physical hit and showed sines of external damage? or did he note there was a code set for a electrical short in the compressor? Yes I have seen way too many pruis compressor fail a year + or - After a front end collision and after a body shop or repair shop repaired the front end. If you still have the paper work that was done from the body shop in the estimate was there a A/C service or recharge or condenser and or radiator replaced? Some times the condenser need just to be removed out of the way to repair or replace something else then put back and recharged. If this is the case I talk about this vary situation extensively in my photo album about body doing a/c on pruis and a year later the compressor goes out and its not from jarring! in 99% . I would like to tear down that compressor to see the bearings and and run a oil analysis on what a/c compressor oil they used ?.
  20. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    did you ever get this problem fixed????
    I wish people would post the fix once they find the problem
