Air conditioner only cools when car is moving
Discussion in 'Gen 3 Prius Main Forum' started by Robert Paulson, May 27, 2019.
  1. Robert Paulson
    Robert Paulson New Member
    Nashville, TN
    Hello,
    My 2014 Prius has stopped cooling the air when I am stopped, but works perfectly fine when I start moving. The air speed stays the same, moving or not, but the air quickly changes to warm when I come to a stop. Anyone know what it might be? Thanks!
  2. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Are your radiator fans running at a idle?
  3. Mendel Leisk
    42,097
    The easy "thought" would be that the fans are not working, that it's only working when the car's speed is causing enough air flow through the front condenser (AC radiator).
    But maybe that's too pat: does it start blowing cool even if you're just rolling slowly?
    CR94 likes this.
  4. ASRDogman
    ASRDogman Senior Member
    7,933
    4,039
    Is the compressor running when you stop?
  5. Mendel Leisk
    42,097
    ScanGuage is one gizmo that can report on that it. Maybe not the most easy. You need to add this XGauge, which is a feat in itself. Look for A/C Power Usage in column A, in the attached spreadsheet:
    Pluggo likes this.
