Air conditioner
Discussion in 'Gen 5 Prius Main Forum' started by Tande, Jul 13, 2025.
  1. Trollbait
    12,814
    The system will switch between them, choosing which is best at the time. In addition to the battery, it could turn recirculate off with high humidity in the cabin.
    daisy555 likes this.
  2. Mendel Leisk
    42,293
    I've found if I've chosen Auto and pushed the AC button, it'll sometimes switch to recirculate for the first few minutes (dash indicates the switch to recirc too), then back to outside air.
    I'd concur, recirc is for special occasions, either to accelerate AC cooling, or due to stinky diesel in front.
  3. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Thanks everyone!
  4. daisy555
    1,729
    716
    CT
    I’m revisiting this topic. I’ve had AC on auto except when I’m getting close to home I turn the heat on. Seems crazy but I’m paranoid about the mold buildup. I’m already smelling a slight odor similar to my 2009 if I just use the AC as one normally would.
    Two days ago I manually switched to recirculate by pressing the switch because I was passing a very cloudy construction area. Now the only way I can turn off the recirculating air switch is to turn on the outside air switch. I guess this makes sense except now the switch light stays on. Before turning the recirculating switch on no lights were on. I don’t get it.
    Also just read somewhere that the rain sensor has been updated / relocated on the 2026 model. Probably improving on the sensitivity. I’m supposed to protect myself from seeing these updates. Ha!
    #24 daisy555, Aug 13, 2025
  5. Hammersmith
    Hammersmith Senior Member
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just press AUTO to give outside/recirc control back to the car. The lights will go off then.
  6. daisy555
    1,729
    716
    CT
    Thanks for the quick response!
