Air Conditioning / Heating Unit , no air coming throught the vents (2007 Toyota Prius)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DrMetal, Jul 28, 2009.
  1. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Had the same problem with my '07. Replaced the fan/motor located under the glove box. A few bolts or screws and it drops right out. If I remember, you can stick your hand in there and give it a push and it starts again. But, it will only get worse. Wish I could be more helpful, but it was a few years ago, and I no longer have a Gen II. Good luck!
  2. JonathonW
    JonathonW Junior Member
    Treasure Island, FL
    I had the same issue and replaced the blower assembly. It took a screw driver, a replacement part, and about 25 minutes. I found the blower on Amazon (search for TYC 700153 Toyota Prius Replacement Blower Assembly) for $43.
    I used the directions in the thread below. DIY!
    Need help changing the a/c blower motor | PriusChat
  3. Bill Brannigan
    Bill Brannigan New Member
    Kennewick, Wa
    I
    My wife has been having a problem with her AC. At first it kicked on after driving for awhile. Now it doesn't work at all. The fan stopped working. The fuse is ok and after taking out the fan it tested fine. I checked and got nothing on the pigtail when testing the AC on low and med speed. I gut a weak signal on high. I figure it's the resister thats the problem. Can anyone tell me where the resister is located on a 2007 Toyota Prius and where I can get one at a reasonable price.......Thanks ......Bill
  4. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
  5. Bill Brannigan
    Kennewick, Wa
    I
    hchu1, Thanks for the info.....I don't see the resister in the blower/motor diagram. Am I missing it ????
  6. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    It should be item #4 in diagram.
  7. Bill Brannigan
    Kennewick, Wa
    I
    Yes, I looked closer and saw it was the Control Module PriusPARTS: Part included in blower assembly... I also saw the prices are real high. The fan is like $100 on that site but I got one for $36 on Amazon.
  8. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Sorry, didn't mean to imply you should purchase there, just use diagram only. :)
    Also, I mentioned above one connector, looking at the unit itself there is two connectors.
  9. Bill Brannigan
    Kennewick, Wa
    I
    Your right there are two connectors. I wish I could see some burn mark someplace. I wonder if there's a way I could test this control Module.
  10. Bill Brannigan
    Kennewick, Wa
    I
    If it's not the resister then what ??? The prius is almost 10 yrs old. AutoZone has it for $150. they also have them used on e bay for $25.
    #70 Bill Brannigan, Sep 3, 2016
  11. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Everything in your pictures look clean. Here is a pdf of wiring diagram for the vehicle. Page 351
    priuschat.com/attachments/wiring-diagrams-pdf.22501/
  12. Bill Brannigan
    Kennewick, Wa
    I
    The only place I see it under $160 is "Arm Auto Dismantler" on E Bay for $25. I wonder if it's worth a shot. These things could last 10 years or 10 minutes. The Prius is almost 10 yrs old.....
    Is there a way to check if the control pad is working ok. I took out the Control Motor that had two connectors. One connector going in and one going out to the fan. Is there a way to check the incoming connector to see if the ac/heat control touch pad is working ok ???? Thxs
  13. JC91006
    16,762
    8,562
    For $25, why not? It's the price of lunch
  14. Bill Brannigan
    Kennewick, Wa
    I
    2007 Prius AC fan checked out OK and the Control blower motor is also good. All connectors to all of these also look good and clean............Any ideas where to look now ?????????????
  15. Bill Brannigan
    Kennewick, Wa
    I
    If you look at the diagram on page 350 it shows a HTR relay that is on the circuit with the AC fan and Control blower motor...Any ideas where this is located ???????????
  16. JoySS
    JoySS Junior Member
    28
    Colorado
    Hi all, looks like this thread hasn't seen activity in a long time. I have a 2006 Prius and the central vents are not blowing air. Side vents fine, AC fine, fan/motor working. Just replaced my air filter 3 weeks ago was running fine until a couple days ago. I have run through all the settings 4 or 5 times to over ride a glitch with no luck. Advice appreciated.
  17. JC91006
    16,762
    8,562
    Are the vents closed? There shouldn't be a reason the side vents work and the center vents don't work.
    Or you have a family of critters stuck in the vent outlet
  18. JoySS
    JoySS Junior Member
    28
    Colorado
    Checked vents, appear to be open. Rolled back and forth closed/open roller, not changing flow, there is nothing coming through even on high. Perhaps something im not seeing from the front end. I have not taken apart to look behind vents yet however have looked under air filter at fan appears fine ( obviously blowing through side vents). What could cause only the center vents to not have air but side ones to work? Any other thoughts?
