Air conditioning noise
Discussion in 'Gen 3 Prius Main Forum' started by EricC, Jul 3, 2009.
  1. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Re: Buzzing sound when the AC is ON.
    Yes.
  2. Welshdog
    Welshdog Member
    181
    38
    Austin, TX
    I have heard it as well. It didn't bother me much, I knew it had to be the AC and besides these cars make so many oddball noises I just ignore them most of the time.
  3. johalareewi
    johalareewi Member
    393
    44
    uk
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It would appear to be normal. There are many other threads regarding this already posted. The noise is a buzz or hum which is loud at first and settles down. It's the electric a/c compressor.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Being a variable speed compressor, the more A/C demand, the higher pitched and louder the buzzing will sound as the compressor spins faster.
    Interesting note: While in ECO mode, the compressor will run at a slightly reduced speed to conserve energy.
  6. HTMLSpinnr
    5,339
    917
    251
    **Merged w/ nearly identical older thread from next page**
  7. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    To add on this: the kind of compressor used is different (it is a [ame="http://en.wikipedia.org/wiki/Scroll_compressor"]scroll compressor[/ame]) and is it of variable speed (speed, therefore noise, change according to cooling demand). Usually, car A/C's doesn't have either of these characteristics.
  8. SPlautz
    SPlautz Junior Member
    51
    Virginia Beach VA
    My 'mechanical airplane buzz' can be heard even while in the car, but mostly while it is stopped. I determined it to be related to the AC right away. However, when it finally does decide to die down, turning the AC off and back on usually causes the sound to come back. Also, it is present when the windshield defrost is on, whether or not the AC is on. I just use it as my alternate horn, i.e. a more pleasant way to warn pedestrians of my approach. I guess it saves me the cost of installing a bell. lol
  9. johalareewi
    johalareewi Member
    393
    44
    uk
    That's because windshield defrost uses the Aircon to dry out the air.
  10. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    My compressor, is also being replaced, under warranty by my dealer. It is important to note that I was involved in a >20 mph front end collision, which impacted the front passenger side of the bumper, etc. Immediately after the accident, they noise from the A/C was a lot louder than before.
    However, my body shop insisted that nothing was wrong with compressor. They brought it to a local Toyota dealership who concluded the same. After bringing to my dealer, they initially tried to say it was from collision, but when state farm asked them to prove it, as there was no damage to the compressor externally, they opted instead to replace it under warranty. I will get my car back tomorrow, and will try to post an update on this when I return from a raod trip next week.
  11. Madjik_Man
    Madjik_Man Junior Member
    50
    Boulder, CO
    I
    So I'm bumping an old thread.
    I just noticed this same noise for the first time since owning the car. Have been running the AC all summer so far. What stands out to me is I never heard this noise before, mainly because the windows would be rolled up and I'm driving. However today I heard the noise inside the cabin with the windows rolled up and driving about 5-10 mph.
    Stopped the car and took this video. The ICE is running during this video yet the AC compressor is clearly louder.
    It's obviously the AC compressor because when I turn off the AC switch inside the cabin, the noise stops immediately.
    I know the consensus for this noise is normal but I would like for someone more knowledgeable about the Prius, than me, to chime in. (sorry, I'm so used to my 1998 Tacoma and old school technology).
  12. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    That doesn't sound right to me. Does the A/C compressor have any outside moving parts? It could be that there is something lodged in there, like a twig or a piece or paper. I would do a thorough visual check and if I couldn't see anything wrong I'd take it to a repair shop. Maybe it's failing from the inside.
