air conditioning schrader valve
Discussion in 'Gen 2 Prius Technical Discussion' started by giperbolic, Mar 23, 2014.
  1. giperbolic
    giperbolic Junior Member
    fl
    I'm trying to replace high side ac schrader valve. It doesn't appear that internal stem is replaceable, rather the whole assembly should be replaced, but I cannot unscrew it. I cannot find a replacement part either. Any help would be appreciated.
    Thank you.
    Mike
  2. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    You should be able to unscrew it. You need a much longer length remover tool to reach the valve than the one used on the tire stem.
  3. giperbolic
    fl
    So the inner stem does come off?
  4. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Yes, the whole assembly will screw out. We used to replace high side schrader innards with high temperature truck valve assemblies back before the factories started using hi-temp valves. If you cannot find a refrigeration kit, you can go that route. I do not know if the new oils will work with the truck valves, however. That should be checked out.
