Air freshner destroyed my Air vent grille!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jesart, Apr 11, 2007.
  1. jesart
    jesart Junior Member
    84
    Hello Everyone,
    I got some bad news. :(
    My Inner right Air vent grille next to the glove compartment, was destroyed by my air freshener. I parked my car at work in an open lot (where I normally park), and noticed during my lunch that the air freshener oil was leaking. The oil spilled on the air vent and literally ate the top layer and stained it. I couldn't take the stain out. No joy, tried everything and the darn thing looks ugly. I called the several Toyota dealerships and the cost for a new one is $157.00 :eek: . Can you believe that?? :angry:
    Part# 55680-47020 Air vent grille - Inner Inner right 2006 (REGISTER ASSY, INSTR)
    So I did a search on the internet and found the same OEM part for $113 at Toyota Parts Center: http://www.trademotion.com/partlocator/ind...m?siteid=214591
    Does anyone know where I could get it cheaper? I am so upset. I would have never imagined that the scented oil would cause damage.
    [attachmentid=7437]
    [attachmentid=7438]
    [attachmentid=7439]
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I say $113 is as cheap as your going to get it new. You might be able to find one at a junkyard cheaper.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Dang :(
    I can't help ya but wanted to thank you for posting this so others may be wary of that junk in the future.
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    You may also want to call the manufacturer of the air freshener and tell them their defective product has damaged your car. See if they will pay for the replacement.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    That panel comes off pretty easily; perhaps you could creatively
    sand its face down and repaint it. Or use more of the air-freshener
    oil and turn the pattern into some entertaining abstract art...
    _H*
  6. just_marci
    just_marci New Member
    49
    <div class='quotetop'>QUOTE(Bill Merchant @ Apr 11 2007, 10:31 PM) [snapback]421887[/snapback]</div>
    I doubt it. Most oil-type products do carry warnings that they can damage finishes.
    I did find this one online at http://www.glade.com/car-air-fresheners/ and it appears to be the same item. They list the precautions and "Liquid could damage some car surfaces" is in there.
  7. jrfaris
    jrfaris Member
    352
    Windward Oahu
    <div class='quotetop'>QUOTE(just_marci @ Apr 12 2007, 06:17 AM) [snapback]421973[/snapback]</div>
    Depends on why it leaked. It surely isn't supposed to. If a product defect caused the leak they might cover some of the costs so it's worth asking. However if it was user error, such has using the wrong refill, then it's not likely they'll be responsive
  8. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    if u search the forums, you should see a post by me, as the same thing happned to me a couple months ago. i also too had to purchase a new air vent. its pretty easy it just comes off with a putty knife, you pull it very carefully.. and a new one just snaps in..
    my damage was worse, it streaked almost all the way down the vent cover with two
    lines of streaking. but yours looks awfully close to the stereo !!.
    oh yeah here it is
    http://priuschat.com/index.php?showtopic=30102&hl=
  9. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    <div class='quotetop'>QUOTE(jesart @ Apr 11 2007, 08:30 PM) [snapback]421756[/snapback]</div>
    Well you could cover it with that burlwood stuff....
