Air trapped in ICE coolant system
Discussion in 'Gen 3 Prius Technical Discussion' started by JimmyBl, Mar 15, 2022.
Tags:
  1. JimmyBl
    JimmyBl New Member
    Missouri
    I have a 2010 Prius. I recently replaced the head gasket in it after having the dreaded knocking on startup and cylinder 1 misfire codes.
    However I fixed those issues I now am having problems in what I’m assuming is air still trapped in my coolant system. I have replaced the thermostat and attempted several times to fire up in manintance mode and bleed air out of the system falling several recommendations I have seen on here and YouTube. But I still get the coolant light flashing for short periods and going back out and on longer runs end up with the coolant reservoir steaming and letting coolant out. Twice now I have blown the small line feeding back to the tank at the plastic y connection. What am I missing here guys. I did have one code for the water temp sensor taking to long to reach temp.
  2. JimmyBl
    JimmyBl New Member
    Missouri
    Also another question if I can feel the coolant flowing in the lines and air bubbles. And see coolant moving in the tank. My water pump should be good or is there a chance of it being weak and not working as well as it should. Sorry just been stuck on this issue and with fuel prices climbing I need this car running.
  3. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    When the head gasket was replaced did the head get machined? Was there any mention of the EGR?
    Just covering the basics here.
  4. JimmyBl
    JimmyBl New Member
    Missouri
    I did tear the egr apart and fully cleaned all the components of it. But I did not have the head machined.
  5. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Engine runs good ? Crept for coolant lite? No missing etc?
  6. JimmyBl
    JimmyBl New Member
    Missouri
    Yes it runs great around town on stop and go traffic. But on longer Highway runs it ends up over pressure the tank and blows my coolant out. But the light never comes on and stays on very long. I’m considering trying a airlift pump to refill my coolant and see if I can get it that way.
  7. ChapmanF
    19,027
    Has a leakdown test been done to confirm the integrity of the head gasket repair?
  8. JimmyBl
    JimmyBl New Member
    Missouri
    No was hoping it was just a matter of air still in the system but may have to consider that option to.
  9. Mendel Leisk
    42,352
    Is coolant level stable in the reservoir?
  10. JimmyBl
    JimmyBl New Member
    Missouri
    If I pulled a vacuum with a airlift would I be able to verify it’s holding by making sure it held vacuum on the system before filling.
  11. JimmyBl
    JimmyBl New Member
    Missouri
    It stays level until I drive on the highway and then the light comes off and on sporadically ie bigger hills. Then goes right back out. I haven’t done a leak down test and didn’t machine the heads but never had this issue before the head gasket repair.
    Also had good heat after last attempt to bleed system
    #11 JimmyBl, Mar 16, 2022
  12. JimmyBl
    JimmyBl New Member
    Missouri
    So today I got a Bluetooth adapter and downloaded torque app. I now think my water pump is bad. It comes up to and holds at 221 with fans on and cap off. Then starts to overflow as coolant heats up. Is there anyway to try to cycle it from the app I don’t have a code for water pump.
  13. vvillovv
    4,337
    1,519
    NY
    Have you tired removing the thermostat that you recently replaced? Sorry that was the first thing that came to mind after reading your post above ^ .
  14. JimmyBl
    JimmyBl New Member
    Missouri
    No I haven’t tried that. I replaced the thermostat cause that was my first thought too that it wasn’t opening. Unfortunately it’s built into the housing and I can’t take it out and put it together without it on there.
  15. vvillovv
    4,337
    1,519
    NY
    If it's not a big job to remove it ? it can be tested in almost boiling water to see if it's opening.
    Sometimes even the new ones stick closed.
  16. JimmyBl
    JimmyBl New Member
    Missouri
    Ok thanks I may try that this evening I rented a coolant gas tester to check if I’m getting exhaust in my coolant. So I’ll let ya know what I figure out there. Also quick question I’m getting a code for my engine coolant temp sensor would that possibly be telling my water pump not to turn on or run hard enough if it’s bad. I’m gonna buy one and change it out and might pull the thermostat back out while I’m tearing back into it.
  17. ChapmanF
    19,027
    In the engine Data List you can watch what speed the water pump is being commanded to run, and what speed it is running, in case you want to check if it's being told to run at a reasonable speed.
    Running full out seems to be around 4600 rpm, from what I saw.
  18. vvillovv
    4,337
    1,519
    NY
    @ChapmanF is refering to techstream above ^
    in case that's not obvious to @JimmyBl already - techinfo.toyota.com
    Chap do you think a sticking thermostat is a possibility?
    #18 vvillovv, Mar 18, 2022
  19. JimmyBl
    JimmyBl New Member
    Missouri
    Well unfortunately I’m fairly certain on my coolant exhaust test I ran that my head didn’t seal up right. Guess good news is I’m already more familiar with what it takes to get the job done. My fatal mistake was I didn’t have the head machined and this time I will for sure. Probably will replace the water pump too while I’m there since I’m getting up there in miles on it. I cleaned the egr system last time I had it all apart.
  20. Mendel Leisk
    42,352
    The care care nut (Toyota master mechanic) was saying you can spot leaks with boroscope that won’t turn the colour with block tester. So pretty much a clincher with the latter.
