Air trapped in ICE coolant system
Discussion in 'Gen 3 Prius Technical Discussion' started by JimmyBl, Mar 15, 2022.
Tags:
  1. ChapmanF
    19,027
    Thermostats sticking closed haven't been anything like common in my own experience, anyway.
    They are opened by the force of expansion of a solid wax pellet. Trying to make that not happen would be like answering the old "what happens when an immovable object meets an irresistible force?" question.
    The only way I know of to create a won't-open situation is an earlier severe overheat, so severe that the wax pellet blew its cylinder apart. Then the thermostat is well and truly dead and will cause repeat overheating, even if it wasn't the reason at first. Thus the usual recommendation to change it in an engine that has badly overheated for any reason.
    In the other direction, they're just closed by a spring, so a bit of rust and stickiness might be enough to stop one from closing completely.
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Did you NEED to machine the head? Did you check to see if it was warped?
    The machine shop would probably check it for you for no cost. You just need a KNOWN straight straight edge.
    Unless you completely flushed the WHOLE coolant system, you may have left over exhaust in the coolant.
    The text may not be accurate. Putting a pressure tester on the coolant system and checking through the
    spark plug holes for coolant leaking into the cylinders would be a better test. And/or a leak down test.
    vvillovv likes this.
  3. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
    There is an air release valve in the back of the engine, you can open it and let air out from there.
    Just zoom in on my picture to follow the tube to where that valve is. 20210517_115715.jpeg
  4. AzusaPrius
    2,257
    945
    These are a couple better pictures so you can see it easier. Screenshot_2022-03-18-17-21-26-1.jpeg Screenshot_2022-03-18-17-20-43-1.jpeg
  5. ChapmanF
    19,027
    Not every Gen 3 has that valve. My 2010 happens to have it. Lots of Gen 3s from later years don't.
    I used to think it was a model-year thing, but they cross the same part number to all years of Gen 3. So it was just a production change at some point.
    But never fear, whether your Gen 3 has that valve or not, all Gen 3s have the degas-bottle style of cooling system. It's built with special extra hoses (the ones shown here in blue) that collect air from high spots in the system and deliver it to the top of the degas bottle where it belongs.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Has classic blown head gasket symptoms. Something got missed or head warped bad.
    Was there some excitement there at the end before you went after that gasket a bad overheat?
    G3 engines are a nightmare.
  7. JimmyBl
    JimmyBl New Member
    Missouri
    The reason I went to replace the head was do to loosing small amounts of coolant and knock at times when cold start and idle long times “in school pickup line” and number one cylinder misfire. No I didn’t have the head check or machines. I have used the bleeder valve every time I’ve attempted to bleed the system it just seems to never be enough no matter what.
  8. ChapmanF
    19,027
    It is most likely not that you are having any trouble burping the air out of the cooling system.
    It sounds more like the engine is just inserting exhaust gas into the cooling system every time you run it.
  9. JimmyBl
    JimmyBl New Member
    Missouri
    Yep that’s my final decision too so Time to redo the head again
  10. JimmyBl
    JimmyBl New Member
    Missouri
    So here’s a update to anyone that cares. I removed the head had it machined and reassembled everything is out still having same problem. After looking around a bit I began suspecting the water pump. But I lacked having a proper scan tool to test it. However I discovered u can remove the water pump and start the car as normal and if u turn the heat on high it will activate the water pump. Mine was running but the impeller was not spinning also I had no codes for the water pump being bad and from where the car was heating up it would force coolant through the system which made it look like it was being pumped. However I had a hard time getting any heat. After replacing it heated quickly and had no issues bleeding the system.
    ASRDogman, edthefox5 and Mendel Leisk like this.
  11. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    If I'm Capt. Obvious here, apologies in advance.
    At very least, after doing the head, there should be a better understanding of the EGR system and one less headache to worry about, if there is a next time with something as confusing - and there is no techstream around to hookup.;)
  12. BiaoH
    BiaoH Junior Member
    46
    Haverford, PA
    One thing I learned from my past experience is that any aluminum head/block need to be machined when replacing head gasket, especially if the head gasket was blown and/or the engine has been overheated. Those aluminum things get easily warped even with normal use.
    edthefox5 likes this.
  13. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Zz engines .. . Look really deep inside . You'll probably replace .
  14. Mendel Leisk
    42,352
    Maybe check them with a straight edge though, verify the need?
