Airbag Off sensor
Discussion in 'Gen 3 Prius Main Forum' started by Nora, Feb 11, 2014.
  1. Nora
    Nora Member
    128
    44
    CO
    Is there a negative effect from turning off the passenger airbag? Not permanently, just with the sensor. When I'm driving by myself, I often dump some heavy bag in the passenger seat, which causes the car to think there's a defenseless little baby in the seat, so the car turns off the passenger air bag. Now, I'm not worried about the life of my bag, but is this bad for the car in some mysterious way I can't think of? The sensor must be sensing all the time, so that won't wear out prematurely. Other than the car judging me negatively for being stupid enough to put this little baby in the seat, is there a downside?
  2. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    None that I can think of. The only downside is if you put something heavy enough on the seat that it turns the airbag *ON*, and then you get into an accident - then you have to pay to replace more airbags and more pieces of your dashboard. I could also see potential danger from improperly secured cargo flying around, or being knocked around by an airbag.
  3. JC91006
    16,872
    8,619
    The sensor is just a scale, it's set at a pre programmed weight to turn on the airbag. There's no sensor other than the weight scale/sensor.
  4. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Just plug the seat belt in and the problem disappears. You can also use it to hold down your rather heavy bag.
  5. Nora
    Nora Member
    128
    44
    CO
    Thanks, I couldn't think of any problem either. That would be some bag to turn the airbag on! :)
  6. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Ah, you've met the missus :LOL:
    Cjeigh likes this.
  7. Cjeigh
    Cjeigh Junior Member
    45
    Winnebago, IL
    I wonder about being able to turn the airbag on? I had a slim 5th grader in the seat and the airbag sensor said, "off"? I no longer let her sit in the passenger seat. But I too have had to move one of my bags to the floor because it wanted the seatbelt on. hmmm?
  8. Nora
    Nora Member
    128
    44
    CO
    I haven't had a bag on the seat that was heavy enough to trigger the "fasten seat belt, you oaf" beeper. That's a heavy bag.
  9. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I so want to make a comment but my conscience has gotten the better of me :LOL:
    Cjeigh likes this.
  10. macman408
    1,179
    368
    In that case, you don't want to turn the airbag on; a small person (whether adult or child) is more likely to be hurt by the airbag, especially in relatively low-speed collisions when they otherwise would have walked away fine. Having the car turn it off automatically is a safety feature that prevents them from getting hurt. With their lower mass, it's fairly likely that the seatbelt will do a pretty good job of keeping them restrained in an accident.
    That said, it's still generally safer in the back seat, even with the airbag off.
    Cjeigh likes this.
  11. Cjeigh
    45
    Winnebago, IL
  12. CapeAnn
    CapeAnn Member
    114
    25
    Northeast United States
    I put my Bichon on the front seat and the Pri asks for a seatbelt. He's only 15-17 pounds.
    I apologize in advance…but I just had to include a piccie of the Pri Pup! Prius Pup.jpg
    Cjeigh likes this.
  13. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Cute (y)
    CapeAnn likes this.
