Airbag On???
Discussion in 'Prime Technical Discussion' started by shebobg, Jan 1, 2018.
  1. shebobg
    shebobg Junior Member
    46
    Woolwich Township, NJ
    This kind of sounds silly but I noticed that when I am in the car by myself in the front seat, I don't notice the Airbag On light in the dash only Airbag Off. When someone else is with me in the front seat, the Airbag On light is on. Is this normal? I looked in the manual and it doesn't mention anything about the Airbag On light to be on even if it is only one person in the front. If this is right, then how do we know if the Airbag is really on when you are by yourself.
  2. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    The lights only display the status of the passenger air bag, either on or off. It doesn't display the driver's, when you're driving you're assumed to be in the drivers seat, so that airbag is on...
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    It's talking about the passenger side airbags only. There is a sensor in the passenger set that detects weight.
  4. shebobg
    46
    Thanks...I thought that might be the case but wasn't sure.
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    There should be some permanent label near the light that indicates it is for the Passenger side, but it's quite faint.
    Jasinswift likes this.
  6. Jasinswift
    Jasinswift New Member
    ua
    Yep its defently should be near the light that indicates.Agree.
  7. Lock N more
    Lock N more New Member
    Fort Lauderdale
    Four Touring
    The truth is, there should be an indicator light for the driver side as well. I understand they want to let you know when something (or someone) in the passenger seat is light enough to turn off the airbag (as to protect a smaller child who could be harmed by the airbag). However, an indicator light telling the driver that the airbag is on (and operational) would be god to know so when it was NOT on, you might know there is a malfunction.
  8. Lock N more
    Fort Lauderdale
    Four Touring
    Is there are separate indicator (like a warning light on the dash somewhere) that will tell me if my driver airbag is malfunctioning?
  9. Lock N more
    Fort Lauderdale
    Four Touring
    Also, since we are on airbags, make sure your car is not one that is included in the airbag recall. I had to have my airbag changes. If you don't the airbag can kill you instead of save you!
