AirConditioning Trick
Discussion in 'Gen 3 Prius Main Forum' started by Smirv, Apr 15, 2010.
  1. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I would like to see cars with auto climate systems have a user setting that would set a maximum fan speed. That way drivers could decide what fan speed and rate of cooling they want, then not have to change settings each time.
  2. hill
    9,038
    You probably know, but the AC is electric ... so yes, the ICE works harder, but it's working harder to keep the traction pack up. No much though. Best thing about backing off AC is the mpg's stay up higher. But it's a trade off. If YOU feel too hot, chances are the traction pack is getting warm. The Prius' ventilation serves both you AND your traction pack ... so don't get too stingy with the AC ... that's all I'm saying.
  3. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    How does the engine work "harder", the AC is electric, its not connected to the engine, opening the windows and expelling the hot air is more realistic and does the job faster.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The AC is electric but anything electric gets its power from the traction battery. As the SOC drops on the traction battery, the ICE must run to recharge the traction battery. The ICE will have to run a little bit more with the AC running in order to keep the traction battery charged.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    If you have a solar moonroof, the air is already less hot. However to further vent some air, I tilt the moonroof and open the rear windows about 1" each. Not so much draft you blow your hair around, but it quickly evacuates the remaining hot air.
    Combine w/ a HeatShield in the windshield, we do ok.
    Remote A/C is icing on the cake.
    As for my setting, if on in the spring I set to 75F, in the summer 78F to keep fuel comsumption down. When it's 110F outside, 78 still feels just fine (and the A/C is running as fast as it will go regardless of setting - turning off Eco boosts that a bit too)
  6. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    remove the windshield and rear hatch glass for "flow through" ventilation.
  7. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    What's with all this "cracking" the windows? Open all four windows all the way, just for a few seconds as you start driving. Then its all done. Some of my other cars, you can hit the unlock button on the key fob and if you keep it pressed, it opens all the windows, why do you think those manufacturers put this feature in? To evacuate the hot air! Don't be a sissy by cracking the window. And as someone mentioned, since the Prius has full auto close on all windows, its makes it so much easier.
  8. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    I would like to see a chop top prius open roadster...someone good with p-shop should sketch one up...bet it would look like a lambo...
