Airflap is not working
Discussion in 'Gen 4 Prius Technical Discussion' started by Fadi1, Oct 22, 2020.
  1. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    As per the technician they informed me that the airflap is not working in my 2017 prius, can you please tell me what it is used for? And whether maybe it is disabled? And when connect the car to obd how to check it?
    Thanks
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Do you know more about - which air-flap?
  3. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    As he said, it is in the front of the car, he told me it is used to save the engine from when the weather is cold and can be open to cool the engine when whether is hot or something like this
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,598
    Taylors, SC
    That's called the grille shutter.
    alanclarkeau likes this.
  5. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    He told me airflap, I'm not sure, how to check if the grille shutter is working? Airflap is something else?
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    I would take it to another technician who knows to call the grille shutter by its correct name.
    You can check to see if anything is lodged into the slats that make up the shutter. There could be debris in it that is jamming it.
    MidwesternBlackSheep likes this.
  7. Mendel Leisk
    42,251
    OP's in Jordan, maybe a translation thing.
  8. alanclarkeau
    7,045
    7,593
    I don't have a GRILLE SHUTTER here in Australia. Maybe someone could photograph where it is for him.
  9. krmcg
    2,592
    2,393
    Whittier, CA
    That's surprising...
  10. alanclarkeau
    7,045
    7,593
    Our thermometers start at 0° C, not 0° F. Seriously - there are some cold spots here - but not cold enough to worry about a Grille Shutter. More likely this type of grille:
    upload_2020-10-23_13-57-30.png Particularly here in the semi-tropics.
    jerrymildred and Mendel Leisk like this.
  11. krmcg
    2,592
    2,393
    Whittier, CA
    Not unlike the Southern California desert climate that I live in...
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    maybe they don't have them in hot climates
  13. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    I don't remember where I got this info for the Gen IV, but... here ya go:
    Edit: I'm pretty sure it came from the Weber Automotive Youtube channel.
    Fadi1 and krmcg like this.
  14. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    I do not know. Maybe you do and you are just unaware that you have one until it breaks and the dealership tells you that you do in fact have one.
    It would however be located in front of the radiator. In warmer/hotter months it will be wide open to allow maximum air to pass through and in colder months it would start out closed to allow the engine to come up to temperature faster.
    If something big enough strikes through to it, it can damage or jam it open/close and throw a code. Personally, I have not had any incidents with it, but some people have.
    krmcg likes this.
  15. RRxing
    2,562
    1,839
    NEPA
    Go to 12:40
    Fadi1 likes this.
  16. alanclarkeau
    7,045
    7,593
    Fairly sure it was mentioned early on that the AUSSIE models don't have the shutters - because we don't (generally) get as cold as you. We've some other differences - the Exhaust Heat recirculation system is missing on ours too.
    Fadi1 and kithmo like this.
  17. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    Thanks for the video so to control it open or close I need to connect to the car, and enable/disable it, it is not automatically?
  18. alanclarkeau
    7,045
    7,593
    As I said - I don't have one, but from what I've read, it's totally automatic - unless a rock, bolt, stick, bird etc gets stuck and stops it moving - or something else untoward.
    Fadi1 likes this.
  19. RRxing
    2,562
    1,839
    NEPA
    If it came with your car, it operates automatically.
    Fadi1 and alanclarkeau like this.
  20. ykbj
    ykbj Junior Member
    24
    2018 Prius
    Technology
    The grille shutter is so flimsy it looks like it wont withstand any type of impact. And the fact it sits so low to the ground doesn't help either. Mine went out last winter hitting some type of ice chuck and since been out of function with an illuminated check engine light.
    Fadi1 likes this.
