Airflow- driving
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Prius4life12, Jan 10, 2022.
  1. Prius4life12
    Prius4life12 New Member
    Pennsylvania
    2018 Prius
    Hello,
    New here. Have owned Prius since 2010. A few months ago I purchased a 2018 Prius non plug in. While driving on the highway, windows up.. my car should like its " sucking air" with my other 3 Prius we own. I have never heard this before...its like the air is not flowing... my mpg is 55+.
    I did see a video months ago, about the front of the car had a vent that needed to be open for airflow...but I am not able to locate..i am unable to find that video on YouTube.
    Any advice would be greatly appreciated.
    Thanks in advance
    Bill
    52,596
    those would be the shutters right behind the grille. they close to help warm the radiator, and open to cool it.
    do you have an owners manual? not sure what you mean by 'sounds llike sucking air', are you having a specific problem?
    alanclarkeau likes this.
  3. Prius4life12
    Pennsylvania
    2018 Prius
    You are correct and I found a YouTube video. Thanks so much. Awesome
  4. Prius4life12
    Pennsylvania
    2018 Prius
    Hi did you get my reply?
  5. bisco
    52,596
    good morning. yes i did, any questions?
  6. Prius4life12
    Pennsylvania
    2018 Prius
    No. Thanks for your help
  7. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    I remember a recent post about road grit getting into the parts of the shutter system that are supposed to rotate and binding it up. I would think that if the ICE was cold and the shutters closed there wouldn't be any commands to the radiator fans to operate. But when the ICE is at operating temperature and the shutters are stuck closed and maybe the ICE gets close to overheating and the radiator fans accelerate in an attempt to cool things off. That might make a sound. I haven't fully explored my shutter system yet to see if it freely rotates or is operated by a stepper motor. Don't try to force shutters open or closed. OP might do some checks with cold Prius made ready. You should observe shutters closed, and warm Prius shutters open. In Prius history there was a time when folks were manually blocking the radiator grill with foam grout backing.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    If the grill shutters were stuck, they would not make a "sucking" sound. They would trigger a trouble code which would turn on a light on your dash. I can't begin to guess what that sound sounds like, so I can't help there other than to say it's not the grill shutters.
    Are you sure it isn't just the tires or the different aerodynamics? Try riding in another Gen 4.
  9. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
    Info:
    AzWxGuy and jerrymildred like this.
