Airlift for Inverter and Engine Coolant
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by ZachAZ, Oct 7, 2025 at 10:32 AM.
Tags:
  1. ZachAZ
    ZachAZ New Member
    Tuesday
    Tucson, AZ
    I couldn't find anything on here about using an airlift to fill your engine and inverter coolant on a 4th gen. I replaced my engine and inverter coolant last night and i used an airlift on both. It worked great. I had to add a little bit of coolant to the inverter when I turned on the pump with the Techstream, but it was mostly full. I also had to add a little to the engine, but again, just a small amount to top it off after running the engine in maintenance mode. 2017 Prime, in case you were wondering.
    51,590
    thanks, great info!
