Airport Parked for 6 Days - Check Engine Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tim Chaten, Dec 1, 2014.
  1. Tim Chaten
    Tim Chaten Junior Member
    16
    IN-CA-HI - Now: Goffstown, NH
    I just got back from a 6 day trip and when I turned my 2004 Prius back on I'm getting a check engine light. We did get a fair amount of snow that I had to clean off.
    The car runs and starts fine so I'm thinking it is just a bug in the computer after sleeping in the snow for too long. Any ideas on what it could be and how to fix it?
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You can get the code read (and cleared) at most any auto parts store. Although unlikely, if it is one they can't see because it's a Toyota specific code, you would need to go to the dealer.
    GOOD LUCK!
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    How many times have you used it since then ?
    How old is the 12 v battery ? Probably a sign that it needs some attention.......like replacement.
  4. Tim Chaten
    16
    The 12V was replaced last year according to the dealer I bought it from. Have driven it twice since then for about 30 minutes each time.
  5. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I know this is simple, but did you try to remove the gas cap, let any built up air escape and put it back on? Just a guess...
    Also, check your fluid levels. While the car is on, remove the cap from your inverter fluid and check for turbulence. That will determine if your inverter pump is working....
    Any noticeable change in performance?
  6. Tim Chaten
    16
    No change in performance - will try the gas cap thing tonight - does it matter if I do that with the car on or off?
  7. Eclipse1701d
    645
    224
    Three Touring
    No. Also, if you truly believe that there is no actual problem, you could disconnect your 12 volt for a few minutes to clear the codes, however, you may have to reprogram your radio stations...
  8. GregP507
    GregP507 Senior Member
    3,002
    481
    How many years has it been since volatile memory went out of fashion? With the price of flash RAM cheap as dirt, it seems like they are going out of their way to use 70s technology to store the settings in the radio. I'm sure there may be a technical explanation for this, but I can't imagine what it would be.
  9. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Actually normal RAM is volatile memory. Memory being volatile means that its information is lost if it loses power. Audi did use one stereo head unit with non-volatile memory but unfortunately they made it in a way that it always stored everything in the memory. So for instance if you rolled volume up and down it did store volume to EEPROM chip tens of times. And EEPROM has only 10 000…100 000 safe lifetime. So almost all of those head units have failed.
  10. GregP507
    3,002
    481
    I have a clock-radio that uses volatile memory to store settings when it's not plugged into power. Every time I plug it in, it sets itself to the correct time, from an internal clock, kept running from a small battery. It cost me $30 in 2007, and it still keeps perfect time. It's hard for me to believe the same thing couldn't be incorporated into an automotive application, that's all.
    #10 GregP507, Dec 1, 2014
  11. Easy Rider 2
    1,584
    258
    Ocala, FL
    First, not sure you can believe the dealer.
    Second, it sounds more and more like you don't run the car enough to keep the battery charged.
    At the very least, you need the battery and charging voltage tested.
    A small automatic charger also is highly recommended; if your battery is not worn out, getting it fully charged and keeping it there might eliminate most of your problems and allow another year or two with the present battery.
    dolj likes this.
  12. Tim Chaten
    16
    I run the car daily for at least an hour of driving - I take at most one or two trips away from the car a year - it gets plenty of use - will the 12V recharge as I drive?
  13. GregP507
    3,002
    481
    Absolutely, that's how it works. It's meant to stay charged when you drive it regularly, but when it sits for long periods, it can discharge for various reasons. Too many discharges (and recharges) can shorten it's life considerably. If this is the normal pattern of use for your battery, you should be using a battery-maintainer or a battery that can better withstand deep-discharges.
  14. Easy Rider 2
    1,584
    258
    Ocala, FL
    Good post but this statement could be a little misleading.
    The driving pattern that he said "daily for at least an hour" absolutely should keep the battery charged......so it NEEDS to be tested.
    The seller could have put in a cheap battery or outright lied to him or something could have happened to it in the past year.
    OR the problem might not be the battery at all.
    IT NEEDS A DIAGNOSTIC VISIT.
    dolj likes this.
  15. GregP507
    3,002
    481
    That's right. I misread it as him driving it infrequently, which is not the case.
  16. Tim Chaten
    16
    So a 6 day stay at the airport with the key fob active wouldn't cause this?
  17. GregP507
    3,002
    481
    It might. The aux battery isn't very large, and something like a security system, a remote starter or some other accessory might draw it down in 6 days. There's also the possibility of internal discharging or corrosion somewhere causing a slow shorting drain.
  18. Tim Chaten
    16
    Looks like it fixed itself - went out for lunch and the check engine light disappeared :)
  19. Mendel Leisk
    42,323
    Sounds like the warning triggered by a loose gas cap. Tightening the cap (fixing the problem) and driving for a few days will shut the light off.
  20. Tim Chaten
    16
    Yea last night at 5PM I reset the gas cap so it could be that
