Aliexpress cheap bluetooth solutions for Prius 2008
Discussion in 'Gen 2 Prius Audio and Electronics' started by Cool-J, Feb 14, 2022.
  1. Cool-J
    Cool-J New Member
    wordwide
    Active
    Hello everyone. I was wondering is this 12 pin the CD Changer port?
    If so, will it fit here?
    This guy clearly states that it WILL NOT WORK for Prius. Although he has exact the same port in the photos.
  2. Umerpk
    Umerpk Junior Member
    24
    Pakistan
    I am using this without BT module
    https://a.aliexpress.com/_mscn3bw
    Pros :-
    1. USB and Aux option
    2. Steering wheel controls working in USB/SD Card
    3. Plug and play
    Cons :-
    1. USB capacity max 8gb
    2. USB has to be made ready by making 06 folders only with max 99 files in each
    3. AUX volume is a bit low
    Overall I am satisfied. You can get its BT module also which I have not used but I assume it to be a better option to use phone music files with steering wheel controls and without any wire
