Alignment, mechanical or high tech? I need a quick answer!
Discussion in 'Gen 2 Prius Technical Discussion' started by Cory Potrafka, Nov 13, 2017.
  1. Cory Potrafka
    Cory Potrafka Junior Member
    51
    Floyd, VA
    I have the option of getting an alignment done the old fashion way (strings, measuring devices. etc..), right by my house, and fairly cheap. Or an hour away (very rural here) for a lot of money, with a laser machine, by a shop I know nothing about. I am inclined to go with the first option but they are not high tech at all, and a Prius kinda is. I can't find any info on this but I do notice everyone talking about wheel sensors and zero point something-or-other and hooking up a device to the OBD2 port. I have faith that this guy can set my alignment near perfect, but is this going to work with my sensors/computers?
  2. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    He may get it just close to the 100% mark. But problem is, Toyota recommends that you use tech stream to perform zero point calibration, when the steering gears being replaced; EPS module, etc.
    Without using tech stream, the steering won't be aligned perfectly.
    Cory Potrafka likes this.
  3. Cory Potrafka
    51
    Floyd, VA
    I have tech stream Is this something I can do after I get it back or something that needs doing while the alignment is in progress?
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Try both situations, and see how it fizzles out.
    Use the utility section on the software, and follow the instructions on how to proceed.
  5. ChapmanF
    18,976
    The alignment per se is mechanical, like other cars; if the shop gets that right, it will drive straight and not eat the tires.
    The point of having the computers relearn the calibration afterward will be so the ABS, stability, and traction control algorithms will be most effective.
    -Chap
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I'd try the old fashion way first. If there isn't much change required, that will be all you need.
    Actually, is there some problem that you're trying to solve? I've got 125,000 miles on my 2006 and it has never had an alignment. Tire wear is symmetric, steering wheel is at center when going straight, and it doesn't pull to either side. Why mess with something that is working OK? On the other hand, my wife's car with about 35,000 miles has extra wear on the left side of the front left tire. It's going to get an alignment with the new tires...
    SFO likes this.
  7. Cory Potrafka
    51
    Floyd, VA
    So I can do the tech stream stuff when I get the car returned to me sounds like. Correct?
  8. Cory Potrafka
    51
    Floyd, VA
    Eating through tires at a ridiculous rate (twice a year), pulling to the right a bit.
  9. Cory Potrafka
    51
    Floyd, VA
    230,000+ on my 2005. I have put on new front wheel bearing hub assemblies and never aligned after that, tho not sure it needs it, did not touch any of the alignment adjusters.
  10. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  11. george a Mitchell
    george a Mitchell New Member
    atlanta
    it can be done but the reason you should have it done at a shop that has the right equipment is accuracy . By doing it there you front and rear wheels will be tracking properly .I did alignments for 25 years before retiring . Irecommend a private shop specializing in 4 wheel alignments .Find one and stick with them . george
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I have had a tire shop do a front end alignment twice over the last 12 years and never did any techstream afterwards. I have techstream.
    Car runs straight as a arrow and 25,000 miles later the tires wear perfectly..
    The front end is no different than any other car mechanically.
    But my car did not pull to the right or anything else but yours does so it may have some big wear issues your string guy will not see. A good alignment guy if he see's something way out he will find out why usually something bent or worn so in the long run I think your better off with the car going for a full front end check up and alignment at the tire store. Tell the guy doing it what your seeing. Tire stores in my area charge $79. for full alignment with print out.
    You did have the TSB done to replace the steering intermediate right? That's very important as it was a steering part that when it failed you would lose steering. If not and its very worn it could affect steering. It was a free replacement years ago.
    This:
    2008 TOYOTA PRIUS | Safercar | National Highway Traffic Safety Administration (NHTSA)
    SFO likes this.
  13. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    The only time you should do it with strings and a tape measure is after doing front end work...to rough it in...so you can get it to the shop and get it aligned properly after. End of story.
