All Auto Window Switches
Discussion in 'Gen 2 Prius Accessories & Modifications' started by vinnysca, Jun 12, 2007.
  1. vinnysca
    vinnysca New Member
    200
    Since the Toyota Prius shares many of its components with the Lexus cars (i.e. switches), has anyone thought of perhaps doing a mod to make all window switches have the auto up and down feature?
    Just a thought... ;)
    Vince.
  2. Tideland Prius
    16,147
    I think people were already having some issues adding one-touch auto to the TCH cause it only has auto-down.
  3. adamorzol
    adamorzol New Member
    65
    Toyota Dealers tell me this is not possible because all the switches on the drivers side are on a solid module.
    Does anyone know how to make the "auto" feature possible for up/down movement on all 4 windows?
    I would like this feature.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    unfortunetly i know this is not as easy as it should be.
    there are certain sensors and relays that the car needs. mainly the crush sensor which is part of the " all the way up" " all the way down" switch.
    the only way to have a switch that goes auto up, is to include a crush sensor. it's simple.. it tells the car that there is resistance in the rolling process and to reverse back down a bit. if you put your hand in your window and auto up, it will go until it hits your hand.. then stop.. and back off.
    maybe they wanted to make sure that robbers couldn't pull people out from the new Camry Hybrid.
    *shrug*
    i want to make this modification myself.
  5. AJMasterson
    AJMasterson New Member
    48
    Now I haven't heard/read about anyone doing an all auto up/down, but I did read somewhere that someone modded the window lock switch to where it would control all the windows simultaneously... that is something I would really like to do myself.
  6. h2photo
    h2photo Member
    432
    Chandler, AZ
    <div class='quotetop'>QUOTE(AJMasterson @ Jun 12 2007, 09:56 PM) [snapback]460656[/snapback]</div>
    I was just going to search/post something about this. Noticed tonight that when the lock is on, you cannot even roll down the windows from the drivers door. Which is really annoying especially when you have to keep the locks on because the dog in the back seat often steps on the door and rolls herself up in the window :lol:
  7. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    Its probably a lot more complicated than expected. I wishhhhhhhhh the prius had 4 window auto. my Scion tC had all window automatic (2 dr 2 window) and I got spoiled with it. It really is a hassel (haha ya I know, lazy times have made me lazy) to have to hold the button the whole time. :p
  8. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(UNWIRED @ Jun 12 2007, 09:25 PM) [snapback]460645[/snapback]</div>
    <div class='quotetop'>QUOTE(h2photo @ Jun 12 2007, 09:58 PM) [snapback]460657[/snapback]</div>
    Yeah, I popped up the driver's side to see if I could do a mod to change the door lock, but saw that it's a solid module. Pity; my last car had a window lock as well, but the controls on the driver's side still worked.
  9. FL Buckeye
    FL Buckeye Member
    146
    WC Florida
    I haven't looked at the power window motors in my Prius, but the schematic shows additional wires going to the driver's power window motor from the master switch so there is some sort of exchange of pulses and/or current that doesn't happen with the other three door window motors. To do this mod I would think you would also need to find donor motors from another vehicle with auto windows, or external modules to copy what the driver's window motor/master switch do.
    I wish I could just have all the windows go down by using the remote, like I could with our Accord. Then some of the heat would be out by the time I got in the car.
  10. loyalscott
    loyalscott Junior Member
    Los Angeles
    thinking about trying to install this aftermarket device which they claim will allow one touch operation:
    2 Window One Touch Up And Down Window Unit- (Up AND Down) AutoLoc AUTWC2000.
    Will photograph and post (if it works).
