All Bars On Battery Indicator
Discussion in 'Gen 3 Prius Main Forum' started by rstark18, Aug 26, 2009.
  1. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Not Solved. ;)
    I just came back from a drive on a road where the display shows all bars, and top top bar stayed the same color as the rest, no matter what settings I changed. I tried every combination of parking and headlights on/off, and dimmer switch positions (off, low, high, full high past click). No difference.
  2. fuzzy1
    10,711
    Try it again at night, and see what you find.
    The color difference is weak, and I believe there are saturation and human perception effects involved. It renders very poorly on my camera and laptop display, but it was very real last night while driving in the dark.
  3. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    If the difference is that weak, can we safely assume this is not a design feature, but rather a display artifact of some kind? Seems like if it was designed to impart information, it would have been made more obvious. Of course, you cannot see the red lines hardly at all on the other display, so then again, maybe not safe to assume yet.
  4. warpedhifi
    warpedhifi Junior Member
    27
    Denton, Tx
    My wife and I just got back from a trip in the mountains, and was able to get 8 bars 4 different times, here is a pic of the event. All in all, it looks the same to me.
  5. fuzzy1
    10,711
    Are you sure? In your picture I'm seeing a hint of color change on the top bar, less than I saw in real life but more than shows on my camera / display combination. Note that the OP's claimed color difference is "slightly".
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I can definitely see a hint of color change in the top bar in your photo. It even looks salmonish to me. Stream's photo, on the other hand, has all 8 bars the same color (although the photo was in torch mode).
  7. DavidA
    2,349
    1,825
    Chicago western burbs
    In the day display mode, when the HSI on my V gets into the PWR area, it is the same greenish color as the rest of the ECO bar. But at night, it is red/salmon. Might the same be true of the top battery bar?
  8. pdth
    pdth Member
    95
    32
    Castle Pines North, CO
    I confirmed this yesterday coming down from the mountains. The top bar is the same salmon color as the "PWR" label, when the headlights are on. Turn the headlights off, the the top bar is the same color as the others. Oncoming traffic thought something must be wrong, flashing my lights like that!
    And a bonus: if the battery indicator is at the second-from-top bar (top bar dark), the second-from-top bar is about halfway between the salmon of the top bar and the greenish of the rest of the bars. Again, only when headlights are on.
