All brake warning light came on when the 12v battery died - yellow line to wheels on when stopped
Discussion in 'Gen 2 Prius Main Forum' started by Swamibob, Dec 3, 2017.
  1. Swamibob
    Swamibob Junior Member
    30
    I have a 2006 prius with 50k miles. My second 12v battery just went out on me. Had to jump it off to get it going again and it lasted a little bit longer when I started driving it more, but I was watching the voltage and it just wasn't up where it needed to be. After the battery died on me, all of the brake warnings came on, prius.jpg
    My question is, do you think this was a coincidence and there is something wrong with a wheel sensor or something like that? Also, is this why it looks like the battery is sending power to the wheels even when I am at a complete stop? I don't think it used to do this and I read on other posts where they said it was brake pressure, but I tried pushing it hard and it didn't stop displaying the yellow lines to the wheels. The car seems to drive and brake fine, feels just like it always has. I was thinking about seeing if some place will read the error codes, then clear them so I can see if they come right back on or not. This may fix it if the low battery is what caused it to error out but not sure if that is a possibility or not.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Not only possible but very likely that the battery is the only problem.
    Get it fixed FIRST.......and SOON. It may die on you the next time in a dangerous situation.
    Scanning for codes with a failing 12 V battery is just a waste of time.
    Charge the new one fully before installing.
    Then check the charging voltage with the car running.
  3. Mendel Leisk
    38,255
    Steps to take:
    1. Check the 12 volt battery's voltage, with the car off, first thing in the morning, with a digital mulimeter. Compare to this chart will give you an idea of it's status:
    (For a more in-depth assessment, DIY load test yourself with something like Solar BA5, or get it to a battery retailer with electronic load tester, see what they say)
    2. Attempt charging, with a smart charger in the 3~4 amp range, see how that goes. A Solar BA5 for one will give an assessment, and also say if it's even worth attempting to charge.
    3. Skip step 2, especially if your multimeter voltage reading is around 12.0 or lower, go straight to battery replacement.
    Raytheeagle likes this.
  4. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
  5. ChapmanF
    15,111
    When using the Vehicle Signal Check screen to gauge battery condition, if you're comparing it to a voltage chart like the one Mendel posted, don't forget that reading tends to be a significant fraction of a volt lower than what you would see with a meter at the battery terminals, and that's if you do the test in ACC. If you do it in IG-ON (as in Carolyn's video), with more of the car being powered up, it will be lower yet.
    That doesn't mean the method is unreliable; once you've learned what the voltage difference is, it's pretty consistent, so if you just add it back to what you see on the signal check screen, you'll get fairly close to what you'd find by digging out the hatch stuff to measure at the battery. In ACC, anyway. In ON, there is more variation of what parts of the car are drawing power, so more variation in the reading.
    -Chap
  6. Swamibob
    30
    I'm sorry all, I appreciate all of the quick replies. I did already replace the battery for the second time with the optima yellow that is for the prius. My old battery was only at 11.4v and was barley able to start the car. By using it every day the battery stayed at 11.5 but if I let it set a few days it would not start so I knew it was totally shot. The new optima using the display check shows 12.5v.
    So I still have all these lights after changing the battery. I was hoping they would go out after changing but they didn't. The question now is what to do next. I just noticed the electric looks like its going to the wheels when I am stopped at a light and pushing the brakes hard do not make it go out. Any way to reset the system to see if the low battery is what triggered all these problems?
  7. Swamibob
    30
    I just went out and checked it again this morning. Without starting the car using the signal check method, the battery shows 12.2v. After starting the car it shows 14.1. Is this normal? It is a new battery.
  8. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Yes, that is normal.
  9. Mendel Leisk
    38,255
    Is that using the car's displays, not a multi-meter? No clue what the fudge factor would be. Maybe get your hands on a multi meter?
    12.2 volts with the car off, with a multi-meter, would be ominously low, fwiw. Anything under 12.5 volts would be setting off alarm bells for me.
    FWIW, our car sits multiple days sometimes, and I just hook up a smart charger, leave it permanently connected, no problems.
  10. kenoarto
    395
    Chicago, IL
    The chart above says it is at 60%. In the green. OK, but not totally full.
    You may actually have a brake problem.
  11. Swamibob
    30
    Do you think that is why it shows power going to the wheels even when I am stopped at a light? Any chance clearing the codes may just fix it?
  12. bisco
    48,998
    low, sometimes new batteries need a charge before installing. if you don't have a charger, leave the car in ready for a few hours at a time, and check the voltage in between.
    a new battery should get close to 13 volts.
    once you know the battery is charged, if the lights don't go out, you can start hunting for the problem.
  13. Swamibob
    30
    Well when I first installed the battery it said it was at 12.5v so I thought that was pretty much fully charged. That was a couple of weeks ago. The car gets driven on the weekends and yesterday we took it to the store for about a 20 min ride. Then it sat overnight and shows 12.2v with the car on acc before switching to ON (pressing the strart without holding the brake) and using the display to check the voltage.
  14. Sam Spade
    2,036
    1,023
    2017 Prius c
    You said that the battery has been charged.......but then what you say after that makes it sound like you don't KNOW that for sure.
    IF......you have not manually charged the new battery, do that. Then leave it disconnected for a half hour or so.
    If that does not clear the codes you REALLY need to get it to a shop for a diagnostic (reading of codes and resetting with the tool).
    Continuing to make wild guesses here might be interesting but likely that it will NOT be productive.
  15. HomeyClown
    HomeyClown Junior Member
    31
    23
    Austin
    I
    This is a quote from another user here at this forum, so this is a copy not a theft. When I replaced the master cylinder in a gen 3 I had to do this same reset to clear the codes. If they come back, you need to address the problem.
    Find the can 2 bus link/ OBD2 port under the dash below your right knee.When looking up at it you will find a connector with 2 rows of 8 pins each. Connect a jumper between pin 4 (CG pin) and pin 13 ( TC pin) on the OBD2 connector. Starting at the top row reading from left to right, pin 4 would be the pin 4 pins away from the left on top row. On bottom row pin 13 would be 4 pins from the right on bottom row. Connect the two pins using a small paper clip, then put the car into ready mode. It will start blinking the ABS light on the dash and the touch screen display will not look normal. Press the brake pedal 8 times or more in 5 seconds after turning the car into ready mode. Turn off the car and remove jumper. The ABS light will not be on. This procedure only resets the light, not the underlying problem. If the original fault is not repaired the light will come on again
  16. bisco
    48,998
    with that driving scenario, you might want to invest in a battery maintainer.
    Mendel Leisk and Prodigyplace like this.
  17. prius8654
    prius8654 Junior Member
    72
    Good call on the smart charger tip. I think it's time to invest in one of those. Any particular brand / model you recommend and or have had a good experience with?
    Also, just like the OP I have the ABS, brake system lights that popped up on the dash during my low voltage issue. I've read that the brake module that sets these lights is sensitive to the low voltage situation caused by a weak 12V battery, so...
    how do you recommend clearing these lights? I tried an OBD adapter in combination with the old Torque app, but of course it couldn't clear ABS codes.
    Thanks!
  18. Mendel Leisk
    38,255
    I’m using a CTEK 4.3, works well. Price has been climbing though, maybe supply and demand with a lot of sidelined vehicles due to COVID?
  19. prius8654
    72
    Okay cool I will check that one out, any thoughts on the second part of my inquiry?
  20. Mendel Leisk
    38,255
