All Electric - Quarter-Filled Gas Tank
Discussion in 'Prime Fuel Economy & EV Range' started by dlegate, May 15, 2018.
  1. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    This car takes care of everything.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Just stating a simple fact.
    No need for name calling and over-reaction.
  3. schja01
    schja01 Senior Member
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    I've read (all) the manuals cover to cover several times and don't claim 100% recall.
    If I had a eidetic memory things might be different.
    I think instead of the curt RTFM response a snippet and page reference would be
    better.
    Just my 2 cents.
    J
    phlack likes this.
  4. sam spade 2
    7,035
    2,803
    2017 Prius c
    I don't own that model.
    And I think it is rude and presumptuous to expect someone else to spend their time doing something that you can do for yourself.
  5. schja01
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    And here I thought this was an information sharing forum. Silly me.
    Krzysiek_KTA likes this.
  6. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Isn't the gas tank a sealed/pressurised system, severely limiting the amount of moist air that can come and go? Also, per the below, Ethanol in the fuel can absorb any little water condensation and burn it off in the Engine? I am actually thinking E10 might be better than E0 in this regard. Also I saw somewhere online that the Ethanol in E10 replaces the carcinogenic MTBE that's in E0. Plus also that Ethanol keeps the injectors clean?
    Car Talk: Fuel tank condensation no longer an issue | News | ncnewsonline.com
    Also the summary last post in the below:
    gasoline - Should I really keep my gas tank at least half full? - Motor Vehicle Maintenance & Repair Stack Exchange
  7. sam spade 2
    7,035
    2,803
    2017 Prius c
    Mostly right. The "sealed" fuel tank is mostly sealed and greatly reduces the moisture infiltration......but does not eliminate it completely.
    MTBE has been outlawed in the US and isn't used in any motor fuel anymore.
    In most circumstances, there is NOTHING wrong with E-10.....but it does tend to deteriorate a bit faster than E0.
    The simple solution to this "problem" is to burn a tankful of gas every 3 months or so.
    Easy. Cheap. But it won't cure anybody's OCD.
    Tips likes this.
  8. srivenkat
    596
    93
    IL
    Thanks for your input. I wonder what E0 has instead of MTBE. Apparently Marina gas could still contain MTBE and shouldn't be mixed with E10 per the below:
    Where Are You Likely to Find MTBE? Beware of Mixing Ethanol-Free Gas
    Is it possible that regular gas stations could also be selling Marina gas (E0 with MTBE) with a label indicating so on the pump?
  9. sam spade 2
    7,035
    2,803
    2017 Prius c
    NO. Illegal.
    Unless maybe it is located very near to a marina and is labeled for "Off Road use only".
    Given the potential problems, I certainly hope not.
    The link you supplied is very good reading.
    Note that fuel systems for boats are generally not as sophisticated as they are for cars.......and gas with ethanol would tend to "load up" with water and eventually not run good. Without the ethanol, the water can easily be trapped in a simple sediment bulb.
    I am not aware the there really is any important difference in "marine gas" except for the absence of ethanol.
  10. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    I think it's always a good idea to keep some fresh fuel in the tank, in MA it's much less expensive to fill up rather
    than charge, as of this writing.
    Regardless, I would burn off and replace the fuel in the tank at least several times per year, even if charging is less expensive, it's nickels and dimes compared to the consequences!
  11. fuzzy1
    10,475
    Here are two more relevant items. First, the fuel systems on PHEVs are far better sealed than on any other cars on the market:
    How designing the Chevy Volt's sealed gas tank brought automakers, CARB together | Autoblog
    and second, from your Prime's Owners Manual, page 104:
    There is no need to be OCD about completely turning it over every few months.
    srivenkat likes this.
  12. sam spade 2
    7,035
    2,803
    2017 Prius c
    OMG. An Prius owner using solid facts and logic.
    How refreshing. :ROFLMAO:
  13. srivenkat
    596
    93
    IL
    In terms of a periodic burn-off, I see an easy to remember metric of 1-mile-a-day (recommended 5.3 gallons/6-months = ~0.5 gallons/month = 27 miles/month = ~ 1-mile/day). So, a trip or two totalling 6 miles/week (perhaps easy to remember if done every Monday or so) (Charge-mode will probably force the Engine to run hot-enough to expel any moisture generated?); this should keep the Engine lubricated as well and assure Engine-availability when really needed.
  14. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    I have 3200 miles in 3 months and 99% EV mode. I just started burning off the original petrol from the dealer when I took delivery, otherwise it would be on Full for the foreseeable future. Any fuel burn-off is going to be challenging and I have to remember to press hybrid mode every time I drive .
    I consider a Full tank an extra 80 lb. of payload (half an adult). Should I just add a few gallons when I get the low fuel warning light? Does the tank have a bladder which prevents an air pocket in the tank?
    What is a reasonable level to keep the tank at since I'm not using any fuel for my normal driving? 1/4 tank is more attractive because I can burn off the fuel and replace it every 3 months at a much quicker interval, too.
  15. srivenkat
    596
    93
    IL
    So, I started with this plan on Monday, forcing Charge Mode over a trip of 6 miles. Engine stayed on for the entire 6-miles due to Charge Mode and lower battery level (as opposed to simple HV mode which would have caused the engine to stop when not needed), so hopefully the engine got hot enough to expel any accumulated moisture and was exercised enough to lubricate all the parts. Will go with the Charge-Mode-for-six-miles every Monday and add 1 Gallon fresh gas every 2-months plan, while keeping the fuel level minimally at 1 or 2 bars.
    Note: I see I have a typo in my original calculation (should be 5.3 gallons/12-months instead of 5.3 gallons/6-months) but it doesn't change the 1-mile/day metric.
  16. schja01
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    Charge mode does a number on your Eco Drive score. I’m getting 20 mpg.
  17. srivenkat
    596
    93
    IL
    Yes, although IIRC, it did add about 5 miles or so to the SoC in my test run, so it's not all that bad. Plus the intent here with Charge-mode is to burn-off some stale-to-be fuel while exercising/lubricating the engine to a hot enough temperature to expel any accumulated moisture in the system and replenish with some fresh fuel and overall increase high availability and longevity of ICE.
  18. schja01
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    Agreed it’s a very effective method to burn off fuel.
  19. not_a_prius
    not_a_prius Junior Member
    anyone was who says gas goes bad is an idiot
    I live in a DRY area never had old gas go bad (10% ethanol)( year old ethanol was fine for me never had an issue)
    what makes it go bad is water getting into the tank if water is getting into the tank you have a bad leak somewhere or you took the car for a swim (flooded out)
  20. fuzzy1
    10,475
    Count me in as one of those idiots. A year ago I tried to start a small gas farm engine that sat fueled in dry storage unused for two or three years. One of those little fuel tanks with a vented cap. No luck, just many wasted pulls of the starting rope. Re-checking the fuel, it appeared the color of urine of someone very dehydrated. After sucking the dark yellow fuel out (no water found) and replacing it with fresh and much more clear fuel, it started right up and ran just fine during a five minute test run.
    Ovation, jerrymildred and Tips like this.
