All interior lights staying on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dr. Nimbus Couzin, Feb 25, 2016.
  1. Dr. Nimbus Couzin
    Dr. Nimbus Couzin Junior Member
    Louisville, KY
    Had this 2015 Prius 4 four a couple months. Today, all of the interior lights, (the two in the front, plus the dome light) are all staying on.
    Any ideas? The switch in the back is in the middle. Messed with it. Didn't help.They are staying on, after locking doors and significant time lapse.
    Is there a switch or button that would do this?
    Thanks!
    -N
  2. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Check, and reclose the hatch? Slam it shut pretty hard.
  3. 48mpg
    48mpg Member
    193
    47
    florida
    I
    see if the dash dimmer switch is turned all the way up.if it is just back it down past the click..the pic is from a 2012
  4. Dr. Nimbus Couzin
    Louisville, KY
    Dash dimmer seems like what it'd be, but still staying on! Might need to swing by the dealer. Hope the car starts this morning!
    Thanks ya'll any more possible ideas? Two month old car, so maybe some malfunction? But that dimmer switch seems like what it would have been. I was sure that would work, but it didn't.
  5. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Is there a switch in your front overhead console? It might be bumped to the "on" position instead of the "door" position or "off" position.
  6. Mendel Leisk
    42,275
    Maybe one of the door switches failed, mimicking a "door open" condition?
    I would disconnect the negative cable to the 12 volt battery as soon as possible, by the way.
    #6 Mendel Leisk, Feb 25, 2016
  7. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    try clicking your lock button on fob with doors closed
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Might I suggest this is normal? The courtesy lights stay on a few seconds after you close the doors. If you come close to the car then the lights come on. You may think the lights were left on the whole time but this is a feature to light the interior as you approach the car with the key fob.
    Try walking away from the car for a few minutes and come back without the fob and check.
    xliderider and Xterra72 like this.
  9. Dr. Nimbus Couzin
    Louisville, KY
    Switch in front roof console did it. I knew there were two switches on left and right for lights, but there is a slider switch in the middle too. Did the trick.
  10. Mendel Leisk
    42,275
    I leave that mother completely off, all the time. I'd rather put up with a bit of darkness than the inevitable drained battery.
    CR94 likes this.
