All signs point to wheel bearing but it's not
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fussion101, May 14, 2021.
  1. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    o_O
  2. Fussion101
    Fussion101 Junior Member
    81
    NYC
    Update: Replaced the cv axle. Not the cv axle.
  3. ASRDogman
    ASRDogman Senior Member
    7,570
    3,904
    Did the noise go away?
  4. Fussion101
    81
    NYC
    Bad wheel bearing like noise(drone) is still there. Tire, wheel bearing, and axle ruled out. What's next? Transaxle? Fluid have been changed out with Toyota WS already.
  5. ASRDogman
    7,570
    3,904
    What brand of wheel bearing? Did you get it from Toyota?
    It could still be bad, depending on the brand.
    You could switch the bearings left to right to left. If the noise moves to the right hand side,
    you know it's the bearing.
    What brand of tires? How many miles on them? Tire pressure?
  6. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    It sounds nuts but I believe I have had similar indications with one tire starting to de-laminate. Was still plenty of tread left, no unusual wear. Could only be seen by removing the wheel and checking the entire circumference visually side to side, or by feel. I had this happen with 5 tires on 3 different Prii.
    rogerdpack likes this.
  7. Fussion101
    81
    NYC
    Bridgestone ecopia ep422. 34 psi all around. I've already moved the front wheel bearings left to right. Noise is still on the left side. Bearings from Toyota parts dept. 6/32 tread. No abnormal tire wear.
  8. Fussion101
    81
    NYC
    I guess I could put on my winter set to see if there's a change. But I doubt it since I already did a tire rotation.
  9. ASRDogman
    7,570
    3,904
    Then there has to be something rubbing. Maybe axel, or brake shield....
    Maybe the inverter pump, or inverter?
  10. broski
    broski Junior Member
    44
    23
    MN
    douglasjre likes this.
  11. broski
    44
    23
    MN
    well I solved mine, it was a wheel bearing. I could tell which it was by holding the suspension spring while spinning the wheel & feeling which corner had the most transmitted vibration.
  12. rogerdpack
    rogerdpack Junior Member
    79
    Enoch, UT
    Spinning by hand?
