All the stuff I've loaded into my Prime's cargo area
Discussion in 'Prime Main Forum (2017-2022)' started by Lee Jay, Sep 26, 2017.
  1. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I remove the front and rear passenger seat headrests, slide the front seat all the way forward, and tilt the front seat all the way back before dropping the rear seat (or maybe the other way around, it only works well one way). That makes a space about 2ft wide by over 8ft long.
    dbat23 and SeattleBebop1 like this.
  2. SeattleBebop1
    SeattleBebop1 Active Member
    163
    105
    Seattle
    Thanks, I'm gonna test this!
  3. SeattleBebop1
    163
    105
    Seattle
    m8547, jerrymildred and Lee Jay like this.
  4. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Just for reference, this 45” x 72” moving blanket is a nice fit. I can’t remember where I bought it but Harbor Freight has some similar ones for $4.
    brenthon, Spidey71, dbat23 and 4 others like this.
  5. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Yep... we've always kept one folded up in the back.Hey, one nevah knows do one!
  6. SeattleBebop1
    163
    105
    Seattle
    Good idea! I keep a big blue tarp in my car. Filthy hiker tip. ;)
    pghyndman likes this.
  7. mrchowmein
    mrchowmein Member
    73
    56
    San Francisco, California
    2020 Prius Prime
    Costco Run
  8. yaun
    yaun Member
    72
    65
    MA
  9. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
    Same
    SeattleBebop1 likes this.
  10. HolyPotato
    HolyPotato Junior Member
    92
    Toronto, Ontario
    So I'm in the early days of planning out my next ride, and thinking I want to go the PHEV route. I love my Gen3 so the Prius Prime is the natural first choice... But I do completely jam the hatch full of stuff at times, so the smaller cargo space gives me pause and makes me think maybe the Rav4 Prime or Escape PHEV may be the ones to look at. Tideland's pic from 2019 (I'm quoting the post if that helps find it) shows that it's roughly the same floor area (maybe a smidge less front-to-back) as the Gen3, but my understanding is that it's shorter vertically (the floor is raised for the extra battery space).
    Yet the Toyota Canada page says the 2022 Prius Prime is rated at 561 L of cargo space, while my 2010 was rated at 445 L. Did they change the way they measure those ratings, or is it that it looks like less vertical space compared to the Gen3, but is actually about the same? Were they not counting the under-floor bin in the 2010, or something else?
    I suppose that when I get more serious I could just go to a dealer with a trunk full of boxes and see how they fit, but PriusChat usually has better answers for me :)
  11. Tideland Prius
    16,684
    They changed the way they measure.
    Previously, they were listing the values closer to VDA measurements (VDA uses 1m3 boxes and fill the cargo space). The numbers they've been using lately appears to be maximum volume (as if you filled the cargo area with water). It's definitely smaller. If I had to wager what the measurement is using the same as the Gen 3's, it's closer to 10 cu. ft (283L).
    Front-to-back, the carpet lifts up about... 1-2"?
    There is less vertical space (And also, keep in mind that the rear glass has a dip in the middle - it's a "dual bubble" rear window so that will further impede into the cargo space).
    If you truly need a boxy cargo area, the RAV4 Prime is definitely the no-compromise solution - it's fast, fuel efficient, spacious and gives nearly nothing up to the regular hybrid or gas version; and there's a spare tyre.
    If you want more luxury, there's the NX450h+ but your range will be reduced (it's a heavier car).
  12. HolyPotato
    92
    Toronto, Ontario
    Thanks for confirming!
    The kid is out of the carseat and pack-the-playpen-and-all-the-things stage, so maybe we could be more reasonable on cargo space, but most likely I think we'll be looking at that Rav4 or Escape for a PHEV (or give up on electrifying for another car ownership cycle and get another regular Prius).
    Edit to add: I relayed that the cargo space is indeed smaller on the Prime to the wife, and she said "But it comes in TEEEEAAAAALLLLL. We can try packing less on the way up north next time..." I know she liked the colour but didn't realize it was worth compromising other things for :)
    #252 HolyPotato, Jul 23, 2021
    Tideland Prius likes this.
  13. Tideland Prius
    16,684
    I mean, isn’t a RAV4 Prime the same kind of “electrifying” as the Prius Prime? Just with more range?
    The other alternative is to get a roof box for the road trips/camping trips. Best of both worlds - efficient low cost commuting and still reasonable fuel efficiency on the highway with a roof box.
    Also the Prius is due for a redesign so if you can wait a year and a half, we might see something late 2022 as a 2023 model.
  14. HolyPotato
    92
    Toronto, Ontario
    Sorry I wasn't clear -- it's definitely still on the shortlist. Just if I was scratching the Prius Prime off said list, perhaps I would add back the regular Prius (which would have plenty of cargo space). I don't love the idea of going up a size class, but it's hard to argue with the no-compromises approach of the Rav4 or Escape PHEVs. I like the idea of getting 90+% of my driving electrified, but OTOH, I don't drive all that much so even in a gas-only Prius I'm not burning that much gas.
    Ok, it's obvious now that you've said it, but I genuinely never thought about that really smart compromise. So thanks (and a smack on the forehead for me). If I can find a roof box or trailer hitch cargo box in teal, it seems like the decision will be taken out of my hands :)
    Yes... I was originally planning on upgrading in ~2022 and hoping the 5th gen would be out by then (and further hoping that Toyota would find a way like with the Rav4 to put the plug-in battery under the car or something to not sacrifice as much cargo space, or bring back the Prius V form factor as a plug-in). But seeing the thread that it had been pushed back to 2023 (maybe 2024?), combined with the spike in used car prices made me think I should start planning an upgrade a bit sooner. So no firm deadlines here, lots of time to think and quibble :) No real reason I can't wait an extra year or two for it to come out.
    [And apologies for now dragging the thread off-topic from what you can fit in your Prius Prime]
  15. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The difference in what can fit in the car between a G4 Prius and a Prius Prime is actually quite small. When I originally looked into replacing my 2004 Prius, I scratched the Prime off the list because of the elevated floor. But then I went and actually measured and discovered that the difference between the G4 and the Prime is smaller than I thought - and in the direction that matters the least (height) - and that the Prime had quite a bit more floor space than my 2004 did, making up the majority of the difference.
    There are things I couldn't put in my Prime but they were things like my new 19 cubic foot stand-up freezer in its shipping box, and it wouldn't have fit in a G4 Prius either. Overall, as you can see from my posts in this thread, it's never been a problem, including taking a family of 4 around the country for 2 weeks without having to do laundry on the trip. It just holds a lot more than you'd think it would, and if you can fold the seats down it really holds a lot.
    jerrymildred and HolyPotato like this.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Same here with one exception. Our new gas grill. I was optimistic and figured the box would fit in the Prime. Nope! It was about one inch from sliding in there but we wound up unboxing it there in the parking lot. Kind of a pain, but we got it home without having to leave it and go get the wife's 2017 Prius. It would have fit in her car with room to spare. That's the only time I felt like I should have had the regular Prius rather than the Prime.
    HolyPotato likes this.
  17. pghyndman
    498
    466
    CT shoreline
    I'm surprised with the stuff I've been able cram into my Prius, but there are times when it just doesn't hack it. Having no desire to own a truck/UTE/SUV, I use a trailer on one of my other cars An open landscapers trailer carries much more than a pickup truck (and is easier to load) while my enclosed trailer keeps things more securely.
    An added benefit is being able to pick up a load of manure,pallet of mulch, etc, drive home and and hitch up to the tractor to bring it where needed.
  18. JamiFids
    JamiFids New Member
    Four Touring
    I do that too. But I don't have a dressing gown, I'll have to buy one.
  19. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    I use a Harbor Freight silver tarp, perhaps 8-feet by 4-feet, in the back. Not as nice of a fit, but the sides cover enough area to 'cup' the center section to keep the sand on the tarp.
  20. jerrymildred
    11,517
    14,171
    Tampa, FL
    I used a moving blanket for years till I broke down and got a Weathertech mat in case of wet spills. But I still like that moving blanket.
    Mambo Dave likes this.
