All warning lights came on!
Discussion in 'Gen 2 Prius Main Forum' started by jgny, Nov 26, 2013.
  1. jgny
    jgny Junior Member
    30
    NY
    The other night, went to start the prius and nothing happened except all the warning lights
    came on! So took the foot off the brake pedal and sat there for a minute trying to figure out
    what the heck happened?? Tried a couple more times and then suddenly it was fine and
    it started! Now I have to mention that the outside temp was around 16*,,, not sure if that
    could have caused this strange reaction?? Any ideas? I sure dont want to be stranded somewhere!
    This is northern ny and we get cold cold harsh winters! :eek:
  2. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
  3. Patrick Wong
    18,200
    6,472
    1. Press hard on the brake pedal while pressing the POWER button, when making the Prius READY.
    2. If the 12V battery is more than four years old, replace it as a preventive move and make sure the new battery is fully-charged prior to installation.
  4. usnavystgc
    3,159
    989
    Tucson, AZ
    I agree this is a classic symptom of a weak 12V battery. When it gets cold, batteries don't perform as well, a weak battery mixed with extremely cold weather will be a nearly dead battery. When you pressed the start button the second time (or however many), the stars aligned and the car made it thru the startup sequence. I highly advise getting a new 12V battery asap.
  5. jgny
    jgny Junior Member
    30
    NY
    I thank you for the reply! Any battery recommendations?
  6. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    For now, if possible, put a battery charger on it, and at least get it as well topped off as it can be. Here on PC there are many who have used the Optima yellowtop replacement from Hybrid parts There are others, as well as the Toyota part, which is pricey. It depends on what is available locally vs. shipping costs.
  7. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Several here recommend Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + , Prius V & Plug-in Prius with Instructions
    Other options are the OEM battery that is sold at the dealer. Also Exide makes a battery for it. O Reilly Auto Parts also stocks a drop in battery.
    Make sure you get a AGM type battery with the JIS reversed posts that is vented.
    File attached covers installation of the battery.
    Whatever battery you get, make sure it is fully charged before you install it. Just because it is new does not mean it is always fully charged.
    Prius I.T. Pro likes this.
  8. Armacham
    Armacham New Member
    Tucson, Arizona
  9. Gorilla97
    Gorilla97 Junior Member
    110
    Edmond, OK
  10. Prius I.T. Pro
    Prius I.T. Pro New Member
    McKinney, TX
    Optima DS46B24R Yellow Top Battery for Toyota Prius with SmartKey System, $189 some places, but cheaper in others, Google's your best friend.
  11. Tom Montefusco
    Tom Montefusco New Member
    Charlotte
    I had same problem. But I was out of gas. The mechanic said gauge shows 3/4 full but there was no gas in engine. He has to recalibrate the sensor I assume
