Alpine F450 5 Channel + 8" Sub Installed!
Discussion in 'Gen 2 Prius Audio and Electronics' started by TimeFor, Oct 23, 2004.
  1. naterprius
    naterprius Senior Member
    1,843
    TimeFor, just checking out the Wiring Diagram shows that the center speaker and the tweeters in the front each come off of the JBL amp on their own channel. It seems as if they are not amplified by the Alpine.
    Nate
  2. TimeFor
    TimeFor New Member
    162
    Fullerton, CA
    I don't know all the technical stuff. I dropped my car off, said "here you go... Install something that sounds good." As for the center speaker.. They didn't know what that does.. And nothing comes out of it now... So Its not hooked up I guess.
    They built the sound package so I'm sure they know what will work. The sub is turned way down... so I'm not worried about it overloading.
    As far as ohms... and all that. ??? . It works, thats all I know. The door speakers are all going to be replaced soon anyways so I don't care what happens to the stock speakers.
  3. starcross
    starcross New Member
    43
    Richmond, VA
    hi timefor or anyone else who have done this already, i just added jbl amp and sub and noticed hissing sound coming from all the speakers.
    furthermore, whenever i turn power of on my car make loud click sound.
    i spoke to my installer and they told me to ask someone who had done this already.
    what kind of LOC did you all used and what was the speaker level set at in amp??
    i would really appreicate anyone's responds!! thanks
  4. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Added JBL amp? Do you mean an '04 OEM JBL amp, or an aftermarket amp? You can't add an OEM JBL amp to a standard system unless you also upgrade the header because in the premium system, the header and MFD control the amp on what volume, EQ, balance and fade to set, with the header sending FIXED line level R & L audio, whereas the base system, sound control is done at the header straight to the speakers.
  5. techogurl
    techogurl New Member
    226
    Fayetteville, AR
    Very nice looking. :)
  6. starcross
    43
    Richmond, VA
    i've added jbl amp gto 755.6 and installer wanted to add LOC, but didn't know what kind...
    also need to know how to set speaker level in amp.
  7. DanMan32
    3,799
    26
    Tampa Bay, FL
    Are you referring to my picture?
  8. tmorrowus
    tmorrowus Member
    514
    This is a great install... particularly like that sub enclosure. If you've got to have a sub, that's the way!
  9. hngu7721
    hngu7721 Junior Member
    50
    TimeFor
    PM sent
