Sold Alpine KTP-445U with custom made Prius T-harness
Discussion in 'Private Sales' started by trentofdestiny, Aug 16, 2016.
  1. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    I am selling my Alpine power pack amp because I don't really need it, I was just curious what it would sound like in my car. It sounds great but I'm happy with just a speaker upgrade and the factory Entune head unit.
    I've made a custom harness to enable you to not have to splice any wires at the radio. Only things you will need to connect are power, ground, turn-on wire. I connected these to the front lighter socket, which goes off with the ignition, making it convenient for you to attach the turn-on wire as well. You may not want to do this if you don't spend most of your drive tie with the radio on as I do.
    The amp is wired so that it is bridged, delivering 90W RMS to each of the front speaker channels only. I was using a 6.5 component set @ 4 ohms in the front when I had the amp attached. By leaving the rear channels alone, you can provide some rear fill or, you may not even hear them lol.
    The amp can be required for RCA inputs or for 45W RMS X 4 channel operation but that would require significant changes to the harness I made for it. Located in Harrisburg, PA. Asking $150 obo. The amp costs this much by itself.
    iPhone ?
  2. trentofdestiny
    1,104
    225
    Harrisburg, PA
    Bump price drop to 130
    iPhone ?
  3. roypaik
    roypaik Member
    161
    39
    Orange County
    2020 Prius Prime
    Hello!
    I am assuming you came from Prius 2 or 3 without jbl? Did you notice any ground noise/hissing?
  4. trentofdestiny
    1,104
    225
    Harrisburg, PA
    Yes it is for non JBL and no I did not hear any noise
    iPhone ?
  5. tannerpace
    tannerpace Junior Member
    42
    charleston
  6. trentofdestiny
    1,104
    225
    Harrisburg, PA
    I don't. I think I sold it on eBay
    iPhone ?
