Alternate storage for alternate flat tire kit?
Discussion in 'Prime Accessories and Modifications' started by solstice, Feb 26, 2018.
  1. solstice
    solstice Junior Member
    Berkeley CA
    Has anybody customized the storage compartment that Toyota custom molded for for their tire compressor/goop kit?
    I am swapping it for a Slime one (would link but I can't get it to work).
    I am pretty sure there is room for it (I removed the molded piece, and there is a lot of empty space under it). It's just a question of the most elegant solution for using the space.
    #1 solstice, Feb 26, 2018
  2. citiprius
    citiprius Active Member
    241
    236
    51
    2018 Prius Prime
    Pull up the 2 rear seat cushion, there are lots of spaces underneath. You just need to secure it so that it doesn't move around and hit the battery (or something looks like a battery) under the middle arm rest area.
    There are only 2 latches under each seat, one at the front middle and one at around the corner, use some force to pull it straight up.
