Alternative to tint.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Godiva, Jul 14, 2005.
  1. Godiva
    Godiva AmeriKan Citizen
    10,339
    Thanks for the link.
    I like this stuff enough to do some of the windows in the house, but the film I got isn't wide enough for two of the windows. This is wide enough.
  2. unique2006
    unique2006 Junior Member
    95
    Riverside, southern california
    After he hands you the ticket :(
    If I get pulled over, it's a simply matter to just peel it off.
    [/quote]
  3. Sid
    Sid New Member
    284
    Pennsylvania
    Now what would be nice is if there were Prius window templates available.
  4. 200Volts
    200Volts Member
    434
    45
    Northern CA
    I bought both the static cling and the regular tint at Kragen. It's only $10 per roll. The optical quality is terrible(orange peel effect), but for the front defroster windows and the rear quarter panel windows it works fine.
    I put the static cling on with water-soap and it goes on and removes easily.
    I put the 5% LTV on the rear window and it's too dark (with the poor optics) at night. I can see a pair of headlights at night and that's about it. I also get a lot of reflections from the inside of the car in the day since my rear doors are not tinted yet.
    I'll try the 20% LTV next on the rear. I cut in with 1 inch extra all around on the rear window since aligning it is difficult.
  5. c4
    c4 Active Member
    607
    51
    That's probably because it was only $10 a roll.. The stuff I've seen, while not as clear as adhesive window tint, was actually not that bad..
