Alternatives to Gen 4 Engine Swap
Discussion in 'Gen 3 Prius Technical Discussion' started by Dexcube, Dec 6, 2025.
  1. Dexcube
    Dexcube New Member
    Arizona
    Hi. I’ve been lurking in this forum for a while as part of my research while considering buying a Prius. Much of that has been considering how to prevent and deal with the head gasket issue on gen 3, and I want to be prepared in case the engine ends up being too far gone for a successful head gasket swap.
    While I would hardly call gen 4 old yet, it certainly is getting older, and it will get harder to find lower mileage engines. I noticed that both the Corolla (Cross) Hybrid and the gen 5 Prius also use a 2ZR-FXE, and was wondering if anyone has successfully put either of those engines into a gen 3.
    From what I’ve heard, the Corolla Hybrid is basically a gen 4 Prius, and the swap would be almost the same as with a gen 4 Prius, except for the fast that the Corolla Hybrid is newer and thus would have a lower mileage engines. I found one person on this forum attempting a swap a few years back (Corolla Hybrid engine vs Gen 4 engine | PriusChat), but didn’t see the results. While it looks promising, I haven’t actually found anyone pulling it off and am wondering if anyone out there actually had. As for an engine from a Corolla Cross, I haven’t found anything about that.
    As for gen 5 Prius engines, while it’s technically the same engine, I’ve got to imagine there are new differences that would have to be navigated verses a gen 4 swap, and so a successful swap probably hasn’t occurred yet.
  2. PriusCamper
    PriusCamper Senior Member
    13,479
    5,446
    Pacific Northwest, USA
    You'll definitely want to talk to this dude in Oklahoma: http://www.skimmilkhybrid.com who did a massive number of Gen4 into Gen3 Prius. He's been thinking what you've been thinking for a while because the quality of used Gen4 engine has gone down. So he decided instead to switch to a full rebuild of Gen3 engines to make them more powerful and more reliable. But then maybe he got more orders than he was interested in doing because I tried to get a couple engines done by him and he always wanted to talk about other stuff.
    It sure would be nice if this discussion found a solution that was better than what's been done before.
  3. Mendel Leisk
    42,384
    What's the miles and has the EGR system (including intake manifold) been cleaned?
    Ah never mind, you're just contemplating a purchase. If you're set on a third gen purchase, I'd try to find one with under 100k miles, be prepared to clean the full EGR system thoroughly. You'll see a lot for sale with over 150k, and odds are about even it's being ditched, with a stop-leak product temporarily holding the head gasket.
    #3 Mendel Leisk, Dec 8, 2025
    Dexcube likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,989
    Texas Hill Country
    A gen5 engine is completely different with 2 liters, dual port and direct injection, different variable valve timing - the list goes on.
    You have to have an almost identical 1.8L engine to have a chance for gen3s elaborate computer systems to work. Even gen4 swaps end up being frankengines with parts of a gen3 bolted on to make things fit.
    So - many have realized the best solution is a rebuilt engine - something dealers and pro shops have known all along.
    A big part of that is eliminating oil burning - which requires revised pistons and rings, along with improved ecm software, egr valve, intake manifold and head gasket.
    You then hope the $2k cat is not 95% clogged from the oil burning.
    Prevention is water under the bridge unless Mendel will sell you his garage queen. Luck is fickle but maybe you will get one of the thousands already updated by Toyota when they did it for free. But clean Gen3s previously updated and not burning oil are unicorns and not often sold for the affordable prices you see on FB Marketplace.
    A low cost "head gasket" fix is a gen3 JDM engine swap. Its lady luck at play again - you win big if the $1k engine is from a 2017-21 Japanese Prius v/+/alpha with all the updates. However there are no US vins to verify year and an inspection at a local JDM engine distributor can only show so much.
    A gen4 engine is best packaged in a gen4 car. The car could be a Prius, Camry or Rav4. Any used car needs a pro assessment before purchase.
    #4 rjparker, Dec 8, 2025
    Brian1954 likes this.
  5. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    The only people who have tired to install the Gen 4 engine in the G3 that have been successful are the ones
    That have used the Gen3 head.
    Too many modifications, and messing with sensors.
    But if you get the updated block, you shouldn't have the issues.
  6. Mendel Leisk
    42,384
    2015 model year gen 3 will for sure have the revised pistons/rings, less prone to develop runaway oil burning. The switch happened partway through model year 2014, at a specific VIN. @rjparker has a nice graphic for when the switch happened.
    Toyota basically hamstrung the gen 3, with low-tension piston rings and newly designed EGR (Exhaust Gas Recirculation) system. Both "innovations" were implement with mpg improvement in mind, and pollution reduction, but in hindsight both were rushed to production with insufficient testing.
    PriusCamper likes this.
  7. Dexcube
    Dexcube New Member
    Arizona
    I made a mistake when looking up the gen 5. I thought it used the same 1.8L 2ZR-FXE, but it looks like that's only in some foreign markets; all US versions of the car use the 2.0L like you said, which means my question for that engine is moot, and I wouldn't have even bothered asking if I'd noticed. Thanks for catching that.
    The rest is mostly stuff I've heard already, as I was mostly asking about the swap itself; my mention of prevention was just contextualizing what I've seen already on this forum, and I'm sorry if I wasn't clear for this. Still, your advice is a nice reiteration of key points.
    indel likes this.
