Altimeter In Automobile GPS?
Discussion in 'Fred's House of Pancakes' started by zenMachine, Dec 26, 2011.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    I wonder if a car that has a GPS with a built-in altimeter could use the data it has of road inclines etc to optimize fuel efficiency.
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The elevation data could be added to the map data base, then when you plot a route, the car could do some predictive battery management, etc.
  3. ETC(SS)
    7,456
    I'm thinking that the Mk-1, Mod-0 eyeball would still trump the GPS/GIS/semi-intelligent adaptive cruise control for the purposes of fuel efficiency.
    Sorry......not trying to pee in anybody's Wheaties. Helluva good idea though.
  4. fuzzy1
    10,673
    A few years ago I heard of some heavy truck cruise control doing this for improved fuel efficiency.
  5. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    If the Prius computer uses a barometer in conjunction with throttle demand to deliver the most efficient fuel mixture, it's already using an "altimeter". As elevation increases the CCs of fuel have to be decreased in ratio with the decreased density of oxygen. Unless the ICE is supercharged - but I don't think it is.
  6. daniel
    14,487
    1,519
    Spokane, WA
    If you're referring to the idea of speeding up on the downhills and slowing on the uphills, this behavior, while improving fuel efficiency, is generally considered to be a poor driving habit, as other drivers cannot anticipate your behavior. It results in either driving over the speed limit at the bottoms, or driving well slower than the flow of traffic at the tops.
    OTOH, the Prius, and especially the PiP with its larger battery, could theoretically use such information to improve battery usage, building up charge when it will shortly be needed for uphills, and depleting battery SoC when a long downhill is about to provide a big regen opportunity.
  7. zenMachine
    3,355
    300
    Some people are better at the manual mode than others. But it wouldn't hurt to have extra help from a car computer either.
  8. fuzzy1
    10,673
    All modern cars -- at least those sold in large enough quantities to need to meet EPA emissions requirements -- do this already.
  9. zenMachine
    3,355
    300
    I was thinking of adding a new and different technology, namely incline prediction in combination with gear changes.
  10. fuzzy1
    10,673
    ^^ understood, but I believe the GPS mapping database would do better as it can look up known elevations on the current road, rather than try to predict elevations ahead based on current trend.
    I was thinking only in terms of cruise control, with built-in slope-aware hypermiling. Were you thinking of ordinary engine fuel management? The closed loop emission control systems do that portion very well already.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Most modern cars use Mass Flow Sensors (MAF) to measure airflow in terms of mass rather than volume, so barometric pressure isn't critical.
  12. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    I want to move where Daniel lives. Where erratic driving behavior is considered slowing going up hills and speeding up going down them. I used to drive in Boston commuter traffic. They have a COMPLETELY different definition there.
  13. daniel
    14,487
    1,519
    Spokane, WA
    The insanity of large cities is one of several reasons why I've chosen never to live in such places. Though I should say that while I love hiking in the mountains, I've always lived in relatively flat places.
  14. zenMachine
    3,355
    300
    Exactly what I was thinking. Knowledge of elevation data, combined with traveling direction and speed, can be computed to provide better gear management, especially when going downhill.
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    There is a patent out for optimized routing based on GPS and topographic data. Someone beat you to the idea.
    Tom
  16. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    We have discussed the idea previously, a topographic map which the GPS accesses to optimize the SOC of the battery based upon an upcoming ascent or decent, etc. I have no idea what the gains might or might not be, though.
    In areas with numerous roads and thus different route choices, I'd imagine that it would require inputting a route for it to work correctly. Otherwise, it would have no idea which way you planned to go.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yes, it would need to know your proposed route to do any useful planning.
    One exmple of how it would benefit fuel economy would be the case where the car is climbing a grade with a downgrade coming up after the downgrade. The car could draw more energy from the battery than it normally would climbing the grade if it knew it was going to get recharged for free on the upcoming downgrade.
  18. zenMachine
    3,355
    300
    Darn!! :)
