Aluminum oil filter housing with drain valve
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Oct 21, 2023.
  1. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Argh, I forgot that. I change the Prius oil at end of May and iQ oil mid Sept, so last one I saw that is fresh in my mind is the vertical one on the iQ….
  2. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
    I do not have to remove the aluminum skid plate at all to do oil changes.
    There is an access panel to the oil filter cut out but the cut was not 100% and oil spills out onto the skid plate.
    This aluminum filter housing will allow me to just drain it right into my oil pan when doing oil changes.
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Added to the quotes archive.
    Khezekiah likes this.
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Bought one of these in preparation to change the oil in a ‘18 Honda Clarity. The drain plug is horizontal shooting oil out horizontally at first. Since Honda says rev engine until cooling fan comes on that oil is shooting out hot and it’s somewhat difficult to catch without spilling every time. I don’t know if you can slide the red drain in between the panel and filter but hopefully there’s enough space. At best because the filter is horizontal in the Prius you drain the top half, if that metal one fits at all…
    FloTool Extender Drain Pan https://www.autozone.com/shop-and-garage-tools/oil-drain-pan/p/flotool-extender-drain-pan/1218934_0_0?searchText=oil+drain+pan?vehicleId=8804601
    EDIT- Maybe you’ll need to trim the red piece to get it to fit in. (At least it is plastic and not metal like the panel is).
    #24 jzchen, Oct 30, 2023
  5. AzusaPrius
    2,184
    920
    Just replaced the old plastic housing with the aluminum version.
    Next oil change will test how less of a mess it will be with this setup.
    Fresh K&N oil filter for high flow. 20240309_113613.jpeg 20240309_130433.jpeg
    amarino and jzchen like this.
  6. Mendel Leisk
    41,425
    What's the dimensions of that square pocket, suitable for 3/8" or 1/2" drive ratchet?
  7. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    3/8 inch, but it would only loosen the small threaded cap on top, not the whole housing.
    SM-G781V ?
  8. Xeico
    Xeico Member
    Folsom
    Can you please share part number of the aluminum version, or link.
  9. Brian1954
    Brian1954 Senior Member
    2,194
    862
    South Central PA, USA
    Toyota part # 15620-40030, and you need a separate threaded plug, which is 15643-31050
    Xeico likes this.
  10. xliderider
    8,140
    3,276
    Honolulu, HI
    Xeico likes this.
  11. xliderider
    8,140
    3,276
    Honolulu, HI
  12. xliderider
    8,140
    3,276
    Honolulu, HI
    Xeico likes this.
  13. Brian1954
    2,194
    862
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    @AzusaPrius That metal clip is there to prevent the plastic cap from shooting out in the event of catastrophic thread failure. Pretty sure it's safe to remove now that you have the metal version..
    Me, I'm running a Dorman plastic cap ever since I accidentally damaged the thread of the OEM trying to reinstall during an oil change...
    CPH2551 ?
