Am having issues with my sks
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dammy, Apr 6, 2021.
  1. Dammy
    Dammy Junior Member
    Nigeria
    My sks not working but the fob button is working.
    I also discover that the central lock is not working when engage my gear in drive. Any help to solve this problem.
    Have check the key button under the dash at the driver side, it at good position. The fob battery is new.
    Am unable to lock or to unlock the door without pressing the fob. Any way out of this?
    52,841
    how is the 12v health?
  3. Dammy
    Dammy Junior Member
    Nigeria
    12v battery was changed 8 months ago. And am still having 12.2v before starting vehicle.
    52,841
    12.2 is low, do you have a charger?
  5. Mendel Leisk
    42,341
    It takes to post #4 here, before someone finally spells out SKS:
    Smart Key System
    I concur; 12 volt sounds neglected.
  6. Dammy
    Dammy Junior Member
    Nigeria
    Yes, but if 12.2 is low what is the recommended volt?
  7. Mendel Leisk
    42,341
    An in-the-pink battery would show at least 12.6, 12.4~12.6 is so-so, lower is action-needed-soon territory.
  8. Dammy
    Dammy Junior Member
    Nigeria
    Thanks, i will check it again and charge it if needed tomorrow.
    But what other things can cause the problem? except the 12v battery.
  9. bisco
    52,841
    a load test must be performed when having problems. batteries with the same resting voltage can have different voltages under load. no way to know the health without one.
    you can find a simple headlight test on line.
    other causes could be in the wiring. i hope it is not
  10. Mendel Leisk
    42,341
    Yes. Any retailers selling batteries these days will more’n likely have a pro-level electronic load tester, and will check your battery for free.
    Dealerships too, but they’re more inclined to ding you for about $50~100?
    you can DIY test with something like Solar BA9.
  11. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    While I agree will everyone that 12.2 V does indicate you need to charge your battery, I do not believe it is the cause of your SKS issues.
    If you measure at the 12 V aux plug in the console with a voltmeter as you start the car and it does not dip below 9.5V, then the 12 V battery is not your issue.
    However, if you want more of a long life out of your 12V you need to be charging it regularly to keep it above 12.6V.
    Unless you know for sure this is an option (and I do not know of any region that had that as an option) that is installed, the Gen 2 does not even have that feature.
    Have the fobs ever worked correctly? Do you know for sure that these are the original fob supplied with the car new?
    From where was the car imported into Nigeria?
  12. Dammy
    Dammy Junior Member
    Nigeria
    It imported from USA
  13. Dammy
    Dammy Junior Member
    Nigeria
    That's what i can't say for sure. Cause the fob button was damage when the vehicle came in, so my mind did not go to the sks until i replaced the fob button.
    #13 Dammy, Apr 18, 2021
  14. dolj
    dolj Senior Member
    8,646
    4,397
    This feature is not available on this generation of (NA) Prius.
    You most likely will need to do a reseed and then re-add your current key fobs.
  15. Dammy
    Dammy Junior Member
    Nigeria
    OK thanks
  16. Dammy
    Dammy Junior Member
    Nigeria
    I saw this on the data list
  17. dolj
    dolj Senior Member
    8,646
    4,397
    I presume you are drawing our attention to the highlighted parameters? I don't know specifically what they do or should do, but the D-Door Touch Sensor and P-Door Touch Sensor ones would relate to the driver's and passenger's door sensors respectively. My guess that these should be ON.
    Possibly P/D-Door Trigger Switch should be ON too.
    Tr/B-Door Lock Switch (relates to the trunk/back door??) should be ON??
    I have no guess for what to do with Key Cancel Switch.
    If it were me I switch them on now at a time and see what happens.
    YMMV.
  18. Dammy
    Dammy Junior Member
    Nigeria
    Yes i know it should be on, but i trying switch it on. There's no option to do that.
    Have tried to reset the tranponder ecu it doesn't reset, have tried to reset the smart ecu it doesn't reset also.
    What am planing to do next is to erase the fob with me and reprogram it back maybe it would work.
  19. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    That's a data list- I would expect each bit to change when that particular switch is manipulated. (ie, push the lock button on the driver's outside handle and one of those should change to ON while it's pressed).
    I wonder which line is for the SKS disable switch under the dash?
  20. dolj
    dolj Senior Member
    8,646
    4,397
    Oh, true so it is. That makes a whole lot more sense. I don't mess around a whole lot in TS and generally, once you've changed a setting, you never do it again.
    WAG, maybe it's the mystery Key Cancel Switch parameter??
    To make changes you need to go back to the 'System Select' tab then you should see a 'Customize Setting' button. Click that and see what options you get. There should be 'Wireless Door Lock', 'Door Lock', and 'Entry& Start' amongst others to choose from.
    In 'Wireless Door Lock' there is the option 'Wireless Control'. Mine is set to ON, is yours?
