Am I a good candidate to own a Prius
Discussion in 'Newbie Forum' started by Bigleftyinaz, Jun 28, 2011.
  1. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    IMO, comments like this, "...looking at a large repair bill..." perpetuate the myth that Prius is a money pit of costly repairs. The potential for expensive repairs is true for ANY CAR when things go wrong especially when a car throws a rod, blows a tranny gear, or a multitude of other internal engine/tranny failures. When considering all operating expenses, Total Operating Costs for a Prius are probably much less than a conventional vehicle.
  2. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    120,000+ miles and $0 spent on repairs
    I just, at 120,000 miles had my first repair at all, the catalytic converter. But that was covered under warranty, so I have spent $0 (although it would have been super pricey if it wasn't). Maintenance costs are the same as any other vehicle.
  3. Bigleftyinaz
    Bigleftyinaz Junior Member
    76
    San Antonio, TX
    Are oil changes less frequent?Brakes ? and whatever there is on this car?
  4. Bigleftyinaz
    76
    San Antonio, TX
    Mike,
    Not sure if I should ask this question in this thread,but I'm wondering if you have seen reports or have done your own- what does this car do for MPG on Fwy At 55 vs 65 and then 75 MPH. Also how much does A/C affect this car?Same as regular?
    Thanks
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Yes on those items. Oil change every 5k to 10k depending on you preference and brakes are good for 150k+ I think mine will be fine to 200k. I'm at 136k and they look great.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    To add to this
    For the 2010+ the recommended oil change interval is 10k, unless you're in severe conditions:
    Toyota defines "severe use" as:
    -mainly being used on dirt/dusty roads
    -consistently used to tow trailers or with car-top carriers or heavy load use (note: the change applied to many 2010 Toyotas, Priuses aren't rated to tow)
    -primarily used for short trips below 32 F / 0 C
    -extensive idling and low speed driving like police/taxi/door-to-door delivery
    Synthetic 0-20 is recommended at least every other oil change.
    And if you try to remember to keep braking under regen and use B mode for heavier braking (I always forget about B so have never used it) your brakes should last on the higher end of estimates.
    It should be noted that the hydraulic brakes are always used at 8mph or less, presumably for safety reasons, so if you do start-stop driving they get a bit more work. The OP however, seems like he is more of a long-distance commuter so will have light brake use. Even with cruise control, the Prius uses regenerative braking.
  8. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    No the Oil changes are at 5,000 miles just like on a normal Toyota, although if you run Synthetic (at least on a 2010+), Toyota says 10k miles between changes.
    Brakes, you will likely have to change your pads and such much less frequently than you may be used to. This is because a percentage of your braking is done via regenerative braking, basically using the electric motor to slow you down and as a bonus charge the battery (part of the reason you never have to plug in the car). So I, and many others have gone well over 100,000 miles with the original pads/shoes in our cars. I currently have a little over 120,000 miles and my pads and shoes are just no where near needing to be replaced. At this rate, I will likely be close to 200,000 miles before having to replace them.
    Depends on the grade of the road, meaning is there a hill, are you accelerating, how constant is your speed, has the car warmed up yet, etc. But at 70MPH on what appears to be a level stretch of road, with the cruise control on, my MPG display reads about 50 MPG. You will actually see it go up and down as you go up and down hills. Really shows you what taxes your gas usage and what doesn't. Running at a constant highway speed is surprisingly efficient. Around town, leaving lights etc. not so much.
  9. Bigleftyinaz
    76
    San Antonio, TX
    Last night I just bought a Prius III in Pearl White.Should be here in about 3 weeks
  10. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Congrats! You will love the car. Blizzard Pearl is the best color, too.:)
