Am I getting scammed by dealer on warranty issue?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by wstt, Dec 9, 2019.
  1. wstt
    wstt Member
    125
    My 2012 Prius v, breaks down 150 miles after getting it serviced by 1 dealer, with an inverter failure which a second dealer says is under warranty, but they come up with $500 of charges they say aren’t covered under warranty. And I get no loaner car for the 6 days I wait for parts and repair.
    My Prius v has an inverter failure and goes into a limp mode, with gas engine providing about 20% power and no electric motor. I immediately get the diagnostic code pulled from an auto parts store and they give me one code, the inverter.
    I drive it in this limp mode about 50 miles total, but drive slowly and I creep up some hills at 8pmh, bc the engine has no power. I am far from dealer who serviced it, so I go to second dealer, which is the only dealer in the area. This dealer says the inverter is under warranty, but they say there are 2 codes pulled, a second one misfire related which isn’t covered. Inverter diagnostic code is covered by warranty so I don’t have to pay the $150 diagnostic fee but the other code they say they got isn’t so I have to pay a diagnostic fee, $150 for this. They said something valve or cylinder related needs to be done and spark plugs changed so total will be $500. They also won’t provide a loaner car while I’m without a car for 6 days as they wait for parts and to fix it. They said they could provide me with a discounted rental car from a local rent a car but at my expense. I think the $500 in charges were from $150 diagnostic fee, and $350 for change of spark plugs and something like a valve or cylinder adjustment.
    Here are my questions.
    1) if there was a misfire would the basic service 150 miles before have picked this up?
    2) would Napa know when pulling codes if there was more than one code?
    3) could this misfire have occurred while I was driving in limp mode as they engine struggled, and after I had gotten Napa do pull the codes?
    4) is there anything I can do like have the dealer show me the second code? I also don’t want to piss them off bc there is no other dealer close by at all. They have monopoly in the area.
    5) to me it seems this misfire / cylinder or value problem occurred bc of the inverter failure as another dealer had just said my car was fine. Can I prove this is because of the warranty problem?
    6) Any suggestions on what to do?
    7) Am I getting scammed?
    Car has 85k miles on it.
    #1 wstt, Dec 9, 2019
    49,371
    i would have them do the warranty work, and refuse the spark plugs.
    after you get it back, start fresh. see how its running and if it throws any codes
    there's usually no reason to replace plugs until 120k
    however, because of the egr issue in gen3, it's possible that you have a non inverter related problem with clogging or head gasket.
    dont waste $500. that may be needed down the road.
    if refusing the plugs upsets them, you are really going to have to drive farther for service, but i would call toyota customer care, and have a talk with the dealership ownr/manager first
    dig4dirt and Tim Jones like this.
  3. wstt
    wstt Member
    125
    More details to the story are I had the car serviced in California just before shipping it to Maui. On the drive to the boat is when this problem occurred. Now it’s on Maui so another dealer isn’t an option for at least 6 months.
  4. wstt
    wstt Member
    125
    the second item they said, the one not under warranty, is that one of the coils or springs is starting to fail. Not sure if that’s critical to get done right away or why it never came up at my recent service.
  5. wstt
    wstt Member
    125
    The second item they said, the one not under warranty, is that one of the coils or springs is starting to fail. Not sure if that’s critical to get done right away or why it never came up at my recent service.
  6. bisco
    49,371
    having read about the dealer situation in hawaii from other members here, i think your best bet is to ask them to do the warranty work and retest the car, physically and with scanner.
    certainly, you can ask for codes, but idk if they have any legal obligation since your not paying for the scan
    Tim Jones likes this.
  7. bisco
    49,371
    not sure what they mean by coil/spring. if it is an ignition coil, that's a possibility with the misfire. if it is a suspension coil spring, i doubt it, unless the car has seen horrific road conditions or an accident.
  8. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Coils and springs...:LOL:
    They did one scan that is part of and covered by warranty, they can not charge additional scan fee for additional findings on the same scan. You are being SCAMMED. SERVCO "Region" is more crooked than Toyota Southeast Region. They are fishing for money because they don't make profit on warranty work.
  9. wstt
    wstt Member
    125
    Sorry, the coil / spring was me just trying to remember what they said. It is the coil that goes with each cylinder. They said one was starting to fail which is why I had the misfire. They also recommended changing spark plugs. But as I stated before, the engine light had never come until the inverter failed. This makes me think that either this occurred when the engine was in limp mode after inverter failure or the dealer made this one up to generate revenue. I did have to creep up a hill when the car was in the low horsepower, gas only mode. Maybe it happened then?
    Frodoz737, can they legitimately say that more work was required than just pulling the code in order to figure out why the car misfired? Can they say that in order to justify why they are charging a second diagnostic fee (with first one covered by warranty) ?
  10. frodoz737
    4,297
    2,348
    33
    The problem is not the Tech...he/she hooks up, runs full diagnostics and report in one shot. The problem is the (commissioned) Service Advisor and/or Management team that supports or turns a blind eye to shady practices and double billing. This is the biggest problem with most Service Departments...and they get away with it because "most" people are ignorant (not stupid) about cars.
  11. wstt
    wstt Member
    125
    Now I really don’t understand things. I got my car back and got some more info, but I’m confused. I chose not to replace the ignition coil on cylinder 2 and the spark plugs for $500. They didn’t replace the full inverter, but parts of it which were under warranty. (Cost would have been $2000, not the $4000 to replace). They did charge me a $150 diagnostic fee for the alleged misfire code they say they got. (Recall, I had the car serviced a few weeks ago and all was fine, then inverter blew, all with in a few hundred miles of last service and when Napa got codes, they didn’t see a misfire code but somehow Toyota did. I also never heard any misfire. ) So inverter goes, and the alleged misfire code Maui Toyota says is unrelated and therefore get a separate diagnostic fee, not covered by warranty, and even though not fixed.
    I asked Maui Toyota to see the report for the misfire code, They show it to me, but won’t let me have a copy, and won’t let me take a photo of it. I then push back so they eventually give me a copy which I’ll attach.
    Now is the confusing part. I get the car back and all is driving fine. A friend hooked up a code reader, and I expect to see no codes, but the same two inverter codes come up. So the ones they fixed are still showing up as active codes, but the one I didn’t fix, and I never saw, doesn’t show up. I don’t know code readers, but the inverter codes that did come up, came up with a yellow light, not a green light or red light. I will say there are no warning lights at all on the car's dash.
    I then call the out of state dealer that serviced the car a few weeks ago and they look up my vin and can see the codes Maui Toyota got on the day I brought it in. They also see on the day I picked up my car, after my car was fixed, codes were checked again, and two codes still came up, the same inverter codes which the service guy thought made no sense. I will say he did see the misfire code initially, but not at the end. He also said that the codes are imported from the computer so they couldn’t be manually entered, but he did say technically if somebody wanted to they could trigger a code.
  12. bisco
    49,371
    what a mess. if you're car is running well, maybe just get back to life.
    if you want to pursue, you'll have to ask why the codes are still coming up, and why isn't there a misfire code any longer, and you want you $150. back.
    but like you said, how mad do you want to make them?
    the downside of living in paradise i guess...
    wstt and dig4dirt like this.
