Am I getting "too good" fuel mileage? Something wrong with my car?
Discussion in 'Gen 2 Prius Fuel Economy' started by Hickey, Feb 3, 2015.
  1. Hickey
    Hickey New Member
    Hi all,
    Sorry, I'm not trying to brag or pretend I'm some sort of amazing hypermiler, I'm just curious if there is a problem with my car.
    Car:
    07' Touring (I think)
    276,000 on the odometer
    Regular oil (10W-30 Quaker State)
    Toyota CVT fluid (forgot spec, sorry)
    "Regular" tires, not LRR ones.
    Nothing else done to it, no plug in mods, etc.
    Driving:
    I live in downtown L.A.
    Mostly city driving below 30 mph.
    Freeway usually means 55-62 mph.
    From almost everyone I talk to that has a Prius around here, tells me they get 48-50 mpg and tell me I'm wrong with my mpg "guesses". Thing is though, I usually get 430-450 miles when I reach 2 bars and then I can only squeeze 7 gallons if that into the tank, which equals 60 ish mpg (last tank was 64). Wondering if that's "too high" for a stock Prius or if there's something wrong with my car, like maybe it's running too lean and engine damage might occur later on?? (I'm a 2 stroke motorcycle rider, so I might be afraid for no reason).
    Also another observation is that the car barely gets warm at all (engine compartment). Maybe that's my being used to my F-250 which creates a massive wave of heat that burns your face off every time you lift the hood, but to me it seems like it's not very hot at all.
    Alright sorry, just curious and thank you for this forum!
    -Hickey
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    That’s good MPG. Normal 4-cycle motor, even Prius engine, is most fuel efficient at air to fuel ratio that’s also safe. No need to worry.
    #2 valde3, Feb 3, 2015
  3. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Your mild climate and moderate highway speeds go a good way towards optimizing your mileage.
    All that heat in your truck's engine compartment had to come from somewhere. Unless you've got a check engine light on the car's doing fine.
    Don't worry about what people tell you. Just enjoy it.
  4. fuzzy1
    10,271
    The only thing 'wrong' that I can see is that you are not spending much time going 70 - 80 mph on the freeway. The mostly low speed city miles open up a lot of room to produce very high mpg if conditions are favorable and you handle them well.
    One possible thing wrong with the car that pops to my mind is tire size -- if the current tires are smaller than original, then the odometer and speedometer shifts will cause mpg calculations to be erroneously high.
    #4 fuzzy1, Feb 3, 2015
  5. ETC(SS)
    6,585
    The reason that people in your neck of the woods sometimes don't get 50mpg and seem to go through brakes every 100,000 miles (or sooner) is because they drive like....well not like you.
    I always tell people that if it runs good, it is good.....and it's really hard for a car to knock down 60 mpg when it's not running well.
    Check your oil volume semi-occasionally and keep doing what you're doing.
    Now....
    I'm going to say something that will completely derail the thread and start a huge, pointless fight.
    Remember my earlier advice....
    Your oil seems a little thick.
    My company car (2010/77,000 miles) runs with 5w30, and there are a lot of oil snobs out there that say that if you don't use their brand/viscosity of oil that you will trash your engine.
    Of course....in your case that would be like telling an octogenarian that they're not eating enough vegetables and getting enough exercise.
    If you've been using QS for very much of the 276,000 miles?
    I'd keep doing that, but you might also look at your OM and consider clubbing down to QS 5w30 and see if you notice any difference.
    Good Luck!
    #5 ETC(SS), Feb 3, 2015
  6. bisco
    49,796
    yep, you're the first priuschatter ever to report going less than 75 in LA.:cool:
  7. Hickey
    Hickey New Member
    Thank you all, as mentioned I get apprehensive when I don't get what is expected out of things, even if it's better than expected. lean and 2 stroke don't mix, and I've rebuilt a share of my engines to know why, haha.
    Anyway, I guess I'll just take it for what it's worth and be happy I have Prius then. :) Last tank was 64.4 mpg (US) while my Civic managed 31, I'm happy with that.
  8. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Congrats--sounds like you're doing things RIGHT! That's a really nice tank average. I've gotten some of my best fuel economy on crowded highways (70mpg for a few days, in the summertime), but I think the best I've done at the end of a tank is 62.
    You're right, the Prius usually produces much less waste heat than a conventional car. In colder weather, fuel economy suffers a fair bit because the car has to run the gasoline engine more just to produce enough heat for the cabin heater. Cold temperatures also reduce the efficiency of the electric drive and the gasoline engine. In warm temps, the Prius can really sip fuel.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Obviously the OP must of been driving through a certain crossroad when he said out loud, "I'd sell my soul for better gas mileage!".
    There's something unnatural happening now.
    Honestly, I wouldn't worry about it. Worry if the gas mileage plummets.
  10. ETC(SS)
    6,585
    Drove through once.
    ....talked to NO ONE! ;)
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Hickey, a 2007 Touring Package 2 has 16" 7 spoke wheels, HID headlights and fog lights but doesn't have nav, leather, homelink mirror, & 6 CD changer. A regular Package 2 has 6 spoke 15" wheels. It doesn't have the same stuff as the Touring 2 and it doesn't have the foglights & HID headlights.
  12. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Lean is mean when talking two strokes, right up to the moment of seizure. But they all make the best power at that point. Good for you for maximizing the potential of your PRI. What two stroke do you pilot?
  13. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
  14. Hickey
    Hickey New Member
    Thank you, I guess I have a Touring but with 6 spoke wheels and an added 6 disc changer and homelink mirror.
    I have a CR250, a pair of CR125 Elsinsores and a CRF230M (4 stroke though). Nothing special.
    #14 Hickey, Feb 5, 2015
  15. The Electric Me
    9,083
    5,798
    Years ago I used that picture as a screen saver.
  16. GregP507
    GregP507 Senior Member
    3,002
    480
    Don't believe the gauges. Set your odometer every time you fill up the tank, and divide the miles covered by the gallons filled. That gives you the true fuel economy number.
  17. GregP507
    3,002
    480
  18. Hickey
    Hickey New Member
    Yep, that's what I do. I find the gauge is pessimistic as last tank, the display read 60.1 mpg and the actual mileage was 64.4
  19. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    I sold my soul to Region One Mental Health, the Devil is only in second place.
  20. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Make sure you average it over several tanks full as there's always some inconsistency with the exact fill volume from one tank to the next. It's quite likely that when you average it out that the displayed mpg is reasonably close or slightly optimistic.
    Given the speeds that you drive then 55 to 60 MPG is perfectly feasible. Similar to yourself, my average trip speeds are not particularly high and the vast majority of my full tank averages (probably more than 95%) are between 55 and 60 MPG (or 3.9 to 4.3 L/100km as we measure it here).
