Am I out of gas, or is the hybrid battery dead?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Roosterleft, Nov 30, 2017.
  1. bisco
    51,968
    you right on the 10 year cusp. do what jc recommended in post #18, many have had good luck with toyota helping to pay for the battery.
    jerrymildred and Mendel Leisk like this.
  2. Roosterleft
    Roosterleft Junior Member
    28
    Fingers crossed. The person I spoke with didn't seem too jolly to help, but I'll know by Monday what they can do.
    51,968
    they always sound like that, just interns taking info. you can also ask the dealer to call them. all the best!(y)
  4. priusrecon
    priusrecon Member
    130
    44
    Upstate NY
    You cannot run out of gas and continue to drive on the battery alone to safety in a Gen II. (How do I know this????)
    It will simply run out of gas and leave you stranded like any other car with only very quick warning signs.
    Unless you are driving it very aggressively, the gas engine will stutter as it starves of fuel....but you will not feel or hear it because it is so smooth, but the car will loose it's "pep" if you press the gas. But it will continue to roll along just fine as the battery and electric motor drain themselves supplementing the lost power as the engine dies. You will see your SOC meter drop precipitously over the course of about a mile or so, but by then, it is too late. The engine continues to run....but only staggers as it starves of fuel. By the time it stops altogether, your HV battery is dead and you are rolling to a stop. No gas, no charge, and stranded.
    I too, monitor my miles since last fill-up and use the average mpg over my tank capacity to determine when to fill next time on my odometer plus a generous safety cushion....and I too, was burned when I ran out less than half way to that estimate. It does happen and it is freakishly odd, since I was only 167 miles into what should have been a 450 mile tankful. I usually put between 8 and 10 gallons in a fill-up, and have found that the tank will take up to 11 1/2 gallons on an experiment. You also have to watch out, because the tank can get very stubbourn on filling and act full when it most definitely is not.
    The good news is, once you fill up, everything is fine once again. I had no issues as a result of the event.
  5. Mendel Leisk
    41,485
    Well, he's tried fill up (4 gallons), and no joy. I'm still wondering if the dealership is being remiss, have heard there's some special charger they can bring in, can recharge batteries drained extraordinarily low, typically due to the out-of-gas scenario.
  6. priusrecon
    priusrecon Member
    130
    44
    Upstate NY
    I would double check on "car will let the battery get dangerously low on a gas run-out situation" theory.
    I personally do not know, but it just doesn't sound right. Perhaps a real techy guy could weigh in on it.
    It may be a weakness of the HV batt that was triggered by the run-out causing it to discharge low, but not an allowance by the battery computer sensing an emergency. Before I'd let a dealership or garage mech sell you an expensive "treatment", I'd get somebody here who knows better to clear it up.
  7. bisco
    51,968
    i ran out in my '08 and drove until the battery quit and the dash lit up. a few gallons of gas, and i was on my way.
    perhaps it depends on the health of your battery to begin with.
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    From your attached image it appears that the battery was at least trying to charge. That is a good sign. If you left it to idle in park did it eventually recharge that battery to 3+ blue bars? Did you try that?
  9. Roosterleft
    28
    No. That photo shows the gas engine as on, and it never kicked on during all this.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hang on, I'm confused now. That was your photo wasn't it?
  11. Roosterleft
    28
    It's my photo. I'm saying that when that photo was taken, and in all the time I was trying to drive the car like that, the engine wasn't on. I'd take that screen with a grain of salt because I don't understand how the engine could be trying to charge the battery when it wasn't actually on.
  12. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    Exactly! A fuel run out or any scenario that prevents the gas engine from running is very stressful on the hybrid battery. Healthy packs can bounce right back but weak packs typically do not. It's the same thing I tell my customers about their 12 Volt batteries, "you left your dome light on and completely drained your battery but it's only 2 years old so it should re charge and be fine, if it was 6 years old and you did that it would be done".
    In my experience there are typically 2 things that can make the ICE stop running 1) It ran out of gas, or 2) The MAF sensor and or intake got so dirty that it wouldn't run anymore. It's normally a 50/50 split between the two causes so before I ever attempt to restart a car in this situation I fill it up, clean the intake and MAF and disconnect/reconnect the 12 Volt battery for a few minutes to reboot the main ECU.
    When you run your hybrid battery down this far you'll only have a few shots at starting the ICE before it won't have enough voltage to role the motor generator anymore.
    Matt
  13. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ok I see. That energy monitor display was an anomaly then.
    I recently had a failed HV battery, but the energy monitor display still seemed to work. It would drive ok for a while with all the warning lights on like yours, and seemingly still using what limited battery capacity was there.
    If I drove it for too long like that however, then it would get really bad and suddenly stop using the battery at all, high engine revs but barely any power. The battery cooling fan would start roaring in the back and the SOC bars would fall, but nothing would make it produce any charge going into the battery. When it did that I stopped straight away and let everything cool for an hour or so, and then it would drive normally again (at least for a while - like it got me home).
  14. Roosterleft
    28
    Update: Toyota offered to cover $2500 of the hybrid battery replacement! That leaves $1000 for me to cover, plus $580 for the ICE water pump replacement and control valve recalibration. @JC91006 Suggested topping off coolant and getting a quote elsewhere- what questions should I ask to know if this is safe to do?
    Raytheeagle likes this.
  15. JC91006
    16,769
    8,567
    CONGRATS!!
    You can ask Toyota corporate to negotiate the price of the battery and price it as "warranty" pricing. That will be much less than "retail" labor rates.
    If they are providing $2500, that should cover almost the entire battery if they price it with "warranty" pricing and not "retail" pricing.
    I suggest you don't do the other repairs yet. They seem very expensive and it's probably a very minor leak you're dealing with. Best to address the battery first.
  16. Roosterleft
    28
    I already “accepted” the offer (they literally asked if I accept. I’d seen this offer on this Forum before so I figured it was the best I’d get). I don’t think I can call back to ask for this. Unless you mean negotiating this with my local dealership?
  17. JC91006
    16,769
    8,567
    You can call back and ask that they price the repair at the "warranty" price rate. That's actually standard practice for them. You can call your Toyota representative as many times as you want. They are just here to help
    What you accepted is $2500 towards the repair.....that's not going to change.
    Prodigyplace likes this.
  18. Roosterleft
    28
    Woohoo! Finally have my car back! I know it’s just one trip, but I haven’t seen MPG this high in YEARS!
    Raytheeagle and Mendel Leisk like this.
