Am I the only one dismayed about the design of the car charging door?
Discussion in 'Prime Plug-in Charging' started by MMBH, May 19, 2018.
  1. MMBH
    MMBH Member
    155
    43
    The point is that it has significant room for improvement, imho....
  2. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    I guess you could probably put it on a gimble so that it rotates out like it currently does but then flips and rotates to a horizontal position to block it from weather. I doubt they'd ever do that thought since it's a weather proof connection and it would just be added weight and cost.
    there's so many other areas for improvement I hope they concentrate on those first!
    51,851
    even though every user has told you it works perfectly, it still bothers you?
    Salamander_King likes this.
  4. MMBH
    MMBH Member
    155
    43
    Yep
  5. MMBH
    MMBH Member
    155
    43
    I agree. Buyers remorse here I guess.... Happy gen 2 Prii family twice over... but not feeling the same love with this one :( I might have been happier with the Volt (like another engineer I know purchased after being a happy Gen. 2 owner) but I thought I'd stick with the Prius... I should have followed his lead as he's happy with his Volt... Or at least I should have waited until it was a few years older and they made improvements... I should have known better than to buy a first year version of a new design... Silly me...
    #25 MMBH, May 27, 2018
  6. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Wait you have buyer's remorse because of the charging door or other things?
    bisco and Raytheeagle like this.
  7. Mendel Leisk
    41,338
    Stick to your guns, man. The natural tendency is to think: it's just a new way of "fueling", but: there's a lot of differences. It's not a few minutes, pouring in fuel, usually under a roof. It's hours, often out in the elements, including snow. And it's electrons, not gas.
    MMBH likes this.
  8. bisco
    51,851
    fair enough.
  9. bisco
    51,851
    agree, there has to be more going on here. o/p, lay on the couch and tell us when it all began.:cool:
  10. bisco
    51,851
    but you don't stand there for hours, just seconds. less than gassing up.
    Raytheeagle and Mendel Leisk like this.
  11. bisco
    51,851
    how does the volt charge door operate?
  12. triggerhappy007
    498
    334
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Some of these are silly! The Leaf's door opens up and you can see the connectors just fine. Also disobeys the weak forces of gravity and stays put after opening thanks to a spring like mechanism, just like how the current Prius charge port door (and fuel door) pop open.
    Only problem is during freezing rain then snow, the ice will form on the upwards hinge and then it acts like a snow dam. Never had it stuck. To be extra greedy I wish I had both a front charge port and a rear side charge port. That way I could back-in and charge in any space and use the charge inlet that suits the scenario best.
    Mendel Leisk and john1701a like this.
  14. bisco
    51,851
    thanks for the pic, that opening is no more impervious to the weather than side opening.
  15. Oniki
    Oniki Active Member
    652
    499
    Colorado
    I doubt that a cover above the port would help matters
  16. Mendel Leisk
    41,338
    Good point.
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It may be hard to tell from the photo, but the charge ports are very much recessed. So much so that you can leave the J1772 connector flap in the open position and still close the lid as if all is well. I may do that occasionally when I'm being lazy :p
    There is also a little LED light in there so that when it pops open the light comes on and stays on for a while. Also very helpful in the dark, one of the very few things Nissan did to the Leaf that wasn't to cut cost and someone was actually thinking about user experience. The list is very very short...
    You can also buy accessories like this charge port door cover. This is perfect for where you gets lots of heavy snow and freezing rain stuffs. After you plug in, you close the cover down and the only opening is the charge handle. I don't have one, but I assume you have to connect and disconnect this cover every time you want to come and go. Something more collapsible may be a better option, don't know if it exists.
    MMBH likes this.
  18. Tideland Prius
    16,549
    Nope and we all know snow rarely falls straight down. If it does, it's light (intensity) enough that it'll take forever to accumulate enough to choke the door (if at all)
  19. Oniki
    Oniki Active Member
    652
    499
    Colorado
    OP: There are some 6B billion people in the world. Odds are at least one agrees with you
  20. Tideland Prius
    16,549
    7 billion now (I know, I still call it 6 billion from time to time)
    benagi and Mendel Leisk like this.
