Am I the only one who keeps thinking I hit something while backing out of a parking spot?
Discussion in 'Gen 3 Prius Main Forum' started by BrettS, Jan 21, 2011.
  1. BrettS
    BrettS Active Member
    290
    136
    Orlando
    Ever since I got my 2010 Prius (about a week ago) I always get a little scare whenever I'm backing out of a parking place. The Prius seems to think that the ideal time to start the ICE to warm it up is when I'm moving backwards and halfway out of the spot... which, of course, causes a little vibration in the car and makes me think I hit or ran over something. It really scared me the first time... especially since I had only had the car a few hours then and I'm mostly used to it by now, but every now and then it catches me off guard.
    I think maybe the car just likes playing with my head;)
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Yeah it's something you get used to and yet other posters think there's something wrong with the car because it wouldn't start in the beginning.
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    They'll do that. OTOH, when I reach for the drivers door to open it in the morning I hear the brake pump start running, it's like the car is greeting me.:D
    Prii are a lot like cats. Sometimes they will show affection and sometimes they just like to mess with you.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The starting seems to become less noticeable as the car breaks in and or you just get use to it, one of the other.
  5. bisco
    49,401
    my wifes hairdresser who had a hycam, it freaked her out so much, she traded it in on a ice cam after a month. hang in there, most of us get used to it.
  6. tinaprius
    tinaprius New Member
    26
    SC
    I always wondered what that noise was in the morning thanks
  7. pEEf
    pEEf Engineer - EV nut
    720
    577
    Berkeley, CA
    You could always put the car in EV mode until you are clear of your parking maneuvers. It's much easier to hear if you actually do hit something if the ICE isn't running!
    Although I can't remember what the original thresholds for EV mode are in a stock Prius, so you may not be able to do it on a cold morning. On my PHEV, I can do it anytime, and I never allow the ICE to run until I'm up to speed on a longish stretch of low-speed road. This way it has time to warm up with a light load, and it's not wasted as much. If I'm not going on a long/highway trip, I just keep EV mode on and never start the ICE at all.
  8. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Wow, Prius owners who forget they have an engine.
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Maybe it's just time to pick Grandma up off the driveway......
  10. bisco
    49,401
    you are making me so jealous. even the new phev won't be able to run without warming up the engine.:(
  11. pEEf
    720
    577
    Berkeley, CA
    Yeah, the Prius warms up automatically because most drivers don't care or would not make the best choice for when to allow it. I like the manual method, as I can choose when the best time is much better than the car's ECU can.
    Maybe someday the PHV Prius will have GPS integration, so you put in your destination and it figures out when would be a good time to warm up the ICE, if at all.
    I routinely make it to the Oakland Airport from my house without ever warming up the ICE. The thing that sucks is if didn't have my block heater plugged in, I have no heat at all!
    The PHV Prius solved the no-heat problem by making the A/C operate as a heat-pump. I wish I could add this to my car!
  12. BrettS
    290
    136
    Orlando
    That's an interesting thought... not so much putting it in EV mode while I back out of a parking spot, but putting it in EV mode in the morning as I leave my house. It's always bothered me that I could make it out of my neighborhood under electric power because the speed limits are so low, but the silly car wants the ICE to run to warm it up. I wonder if I'll see any gas mileage improvement if I put it in EV mode and let the ICE stay off until I actually get out to the bigger road where I need it anyway. Let it warm up while it's actually being used.
    On a side note, I've definitely improved my gas economy driving skills over the week I've had the car. I have a 25 mile commute to work (about 15 highway miles and 10 non highway) and the first day I drove it to work I averaged 48MPG for the trip. This morning I did the same trip with an average of 54.8MPG (although I was really annoyed that I didn't hit 55;) ). That's according to the car's trip computer, which was reset immediately after turning on the car (before I started moving and before the ICE came on to warm up).
  13. Capt Ed
    Capt Ed Junior Member
    I believe that she was referring to the brake pump noise that OS650 mentioned. I wondered what that was also, so I extend my Thanks to Os too!
    Ed
  14. macmaster05
    macmaster05 Senor Member
    4,050
    729
    you mean XS right?
  15. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    I stand corrected.
  16. Capt Ed
    Oops! Yes indeed. I stand corrected too! Thank You!
    Ed
  17. Canard
    Canard Member
    208
    38
    Ontario, Canada
    Did you just make up those terms? :)
    -Iain
  18. Mendel Leisk
    38,665
    I took the title literally. I've been backing up once or twice and found the brakes very grabby, so much so that I thought I'd, well: hit something. Could be especially just at start-up.
    Anyone else note that?
  19. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Occasional grabby brakes in reverse are a known but not universal issue http://priuschat.com/forums/gen-iii-2010-prius-main-forum/65875-braking-in-reverse.html
    Happened to me a couple of times more than a year ago but not since.
    While its not been a big deal for most people, hopefully Toyota will resolve it with a program update one day.
  20. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Until Toyota finds a cure for it, you can relieve it temporarily by lifting your foot completely off the brake pedal and reapplying it. Instant cure for the time being.
