Am2 fuse blown, p3018 and p0420
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mahal, Sep 14, 2020.
  1. Mahal
    Mahal Junior Member
    16
    Panamá
    I was driving and p3018 code pop up, I already were dealing with the hybrid battery modules, so I imagine I didn't replace all the modules were bad. But when I was parked suddenly the prius shut down and the power button didn't do anything, the am2 fuse was blown so, I wanted to know if the hybrid battery dead could be the cause the damage fuse.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Raytheeagle, bisco and Mahal like this.
  3. Mahal
    Mahal Junior Member
    16
    Panamá
  4. Mahal
    Mahal Junior Member
    16
    Panamá
    Well, I can't even start the car.
    And, last year I change the coolant pump
  5. bisco
    52,804
    did you replace the fuse?
    was it an oem pump?
  6. Mahal
    Mahal Junior Member
    16
    Panamá
    I haven't replace it, yet
    Yes, it is oem pump
  7. bisco
    52,804
    make sure it is workong per sfo above
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Using a voltmeter/multi-meter, what does the 12v battery voltage read?
    You may need to charge the 12v to get the vehicle to turn on, which will then allow the HV battery to start the ICE.
  9. Mahal
    Mahal Junior Member
    16
    Panamá
    I just buy a new 12v battery two weeks ago
    I ask before if the car can start with de Hybrid battery under 200v, and people answer me that, it will not start. But I want to be sure if a fuse could be burnt for saving the battery from damage. Just to discard other problems.
  10. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Disconnect the inverter coolant pump (picture below), and then replace the AM2 fuse, does the vehicle start?
    Be sure to replace and reconnect the inverter coolant pump before driving again.
    Mahal and Raytheeagle like this.
  11. Mahal
    Mahal Junior Member
    16
    Panamá
    Yes, it was the coolant pump...again.
    But, I'm upset because It's the second time it happens.
    What can I do to prevent it burn again?
    Thanks for your help
    SFO likes this.
  12. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Not sure there is anything you can do, beyond using OEM parts and purging the inverter coolant loop of air.
    That failed pump should be covered by a one (1) year warranty at the dealership, get a free replacement.
