Amazing vehicle
Discussion in 'Gen 2 Prius Main Forum' started by Youngmroverland, Jan 16, 2025.
  1. Youngmroverland
    Youngmroverland Junior Member
    I have to share what an amazing vehicle our 2008 is. For winter driving I have dedicated Michelin snow tires on steel wheels.
    For the holidays we visited San Diego. On our return we encountered bad weather North of Wichita. We were trying to beat it leaving Albuquerque at 4a.
    Unfortunately we had an incident in Emporia where we slide in a turn and drove over a median. Blew the LF tire and damaged the wheel. I threw the spare on and we tried to continue but she did not drive right.
    We spent the night at a hotel and in the morning I swapped the spare to the LR and put a good snow on the LF. I noticed the lower control arm on left was bent but nothing else appeared damaged.
    We decided to take the chance on the 120mi drive home. It was snowing and only forecast to get worse. AAA had already let us know the tow had cancelled due to extreme weather forecast. We didn't want to be stuck for days in Emporia.
    We drove 7hrs at about 20mph but made it back to KCMO. Luckily the weather was so bad no one was on the road.
    I can guarantee we would not have been able to make it without the snow and snow tires.
    Love this lil'gem that is just about to hit 290k mi.
    https://drive.google.com/drive/folders/1bGgA8jt0DShCYiGfinSzsSUh-eW66A5F
    97trophy likes this.
  2. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
  3. Youngmroverland
    I have done the restack and balance of hybrid battery. New 12v battery. Replaced struts on all four corners. Both front wheel bearings. Both lower ball joints. L lower control arm replaced. R lower control arm rebushed. Front pads and rotors. Replaced all fluids. And a catch can.
  4. pasadena_commut
    pasadena_commut Senior Member
    3,038
    943
    Southern California
    Glad you made it home instead of turning into an icicle. That was a distinct possibility since 140 miles is twice the maximum recommended distance for a space saver spare (which I assume is what you had as this is standard for the car). If that was at normal temperatures the usual recommendation would be to replace it. However, since this was in freezing conditions it likely didn't get hot, so maybe not? If it was mine, I would replace it now, regardless of the amount of visible tire wear. (Bet it's 17 years too.)
    Youngmroverland likes this.
