Amazon Basics CR1632 battery lasted less than 4 months in keyfob
Discussion in 'Gen 3 Prius Main Forum' started by Aenima, May 29, 2023.
  1. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Those battery tests down to 2.0 V are absolutely meaningless when it comes to keyless entry/keyless start. Test the voltage of a low one (per Prius display). I don’t think I’ve ever seen one below 3 V (using a decent multimeter)….
  2. DPri
    DPri Junior Member
    40
    Earth
    Energizers usually last 3 years plus/minus couple of months in my remotes. Don't buy from fleabay or amazon...
  3. ETC(SS)
    7,139
    Just bought a Sig Romeo 5.
    Their rating for the included CR1632 is 40,000 Hours (4.5 Years.)
    The included battery.....a for-real Energizer lithium.
    I'll let PC know in 4.5 years if it lasts that long..... :cool:
    Don't know what a Romeo-5 is?
    Not surprised.
    No sweat. Gotcha covered.
    Sig Romeo 5 Review: 4 Years Tested - Pew Pew Tactical
    51,891
    i bought a bunch of LICB batteries from amazon a year or two ago. they've been fine so far. i usually get 4-5 years out of the key fobs.
    just got some amazon basics 9 volt. $1.62 each last were duracells, but i can't believe the current prices. checked home depot, just as bad.
    #24 bisco, Jun 1, 2023
  5. Gokhan
    Gokhan Senior Member
    6,181
    2,441
    Paramount CA
    Dollar stores tend to sell cheap coin cells.
    The next best place to buy coin cells and button cells is eBay.
    Energizer, Duracell, Panasonic, Maxell, etc. are all good brands as well as many Chinese brands such as Tianqiu.
    Remember that China is the No. 1 manufacturer of batteries, and they are the world expert on battery manufacturing; so, there is no such thing as a cheap Chinese battery.
  6. ETC(SS)
    7,139
    Do NOT concur.
    While it is true that Chinese companies are capable of producing high quality batteries, there are MANY MANY MANY examples where manufacturing facilities in the Middle Kingdom produce inexpensive fecal matter.
    ---just like everywhere else.
  7. Gokhan
    6,181
    2,441
    Paramount CA
    You won't go wrong with Chinese-made third-party name brands sold at dollar stores like ACDelco or highly rated Chinese OEMs on eBay like Tianqiu. I've never had problem with either ACDelco or Tianqiu.
    https://www.ebay.com/itm/334322619891
    https://www.ebay.com/itm/155380481681
  8. fuzzy1
    10,431
    Then where are the low performance batteries coming from?
  9. bisco
    51,891
    pakistan
  10. Aenima
    Aenima Junior Member
    32
    17
    Phoenix
    UPDATE: the problem is definitely the key fob, NOT the batteries. I assumed since when I bought the car, the battery that was already in the fob lasted 8 months and the new Amazon Basics battery lasted less than 4, that the battery must be the problem. Guessing I the fob was damaged from a drop or something.
    Gokhan likes this.
  11. Gokhan
    6,181
    2,441
    Paramount CA
    Yes, that happens, and it is sometimes very easy to repair.
    It happened to my gate-opener fob a few weeks ago, which uses a CR2032 lithium coin cell. It turned out that the solder on one of the posts of the cell holder broke off and the post lifted off, and the circuit board was no longer able to make contact with the bottom of the coin cell (negative terminal). I resoldered both posts, and it is now better than new.
    If you are looking for cheap coin cells or button cells, Tianqiu cells are excellent—they are practically no worse than Panasonic cells:
